v8s problem
Results 1 to 13 of 13
Thread: v8s problem
    Mar 2016
    Exclamation v8s problem
    hi,a mate as had an openbox v8s for over a year now without any problems,he installd a new line a few weeks ago,again no issues until yesterday,all pay channels,except documentaries and sports are clearing ,so the line is ok ,so could this be a firmware problem?any suggestions,thanks .
    gary229's Avatar
    Sep 2010
    Quote Originally Posted by hatchet123 View Post
    If your mate has been updating channel lists using a usb then its best for him to try this menu> factory settings> ok on yes> IMPORTANT now press blue. This will erase all channel list data, reload Cwaites list and that should sort it.
    I will add though I know of two folk recently that have the same issue and funnily enough the documentaries wouldn't clear, strange.
  3. The Following User Says Thank You to gary229 For This Useful Post:
    hatchet123 (21st May, 2016)
    Mar 2016
    thanks for your reply, will try later
    Mar 2016
    tried what you suggested but no joy,its strange, gold wont clear but gold+1 does,sly sports wont clear but bt sports does,firmware onthe box is :-3511hd_07-12_2014 0923,do you thimk this needs updating,thanks
  6. #5
    P&D's Avatar
    May 2010
    Just upgrade the firmware & see you won't know till you try.........
  7. The Following 2 Users Say Thank You to P&D For This Useful Post:
    hatchet123 (21st May, 2016), monkeyboy600 (15th February, 2017)
  8. #6
    Dec 2009
    I've had this issue for ages, tried nearly everything, including putting older firmware, but the box never seems to erase all the way back to factory settings?
  9. #7
    Nov 2015
    Some .................................................. ..
  10. #8
    Moderator
    PremierD's Avatar
    Jun 2009
    Some planks .. need to read these ..
  11. The Following User Says Thank You to PremierD For This Useful Post:
    digicon (23rd May, 2016)
  12. #9
    Nov 2015
    I'll rephrase some lines only work on selected channels it's not your firmware. Get another line
  13. #10
    Nov 2015
    Sorry for being a plank I was only trying to help will be more careful in future
  14. #11
    Dec 2008
    When i upgrade the above software for V8S with USB it says Software OEM ID Mismatch please help
  15. #12
    P&D's Avatar
    May 2010
    Quote Originally Posted by paul93 View Post
    The link above is the old software try this link for the new up to date software...http://www.openbox.cm/index.php?c=article&a=type&tid=2
  16. The Following 2 Users Say Thank You to P&D For This Useful Post:
    badboy1965 (23rd January, 2018), Teltech (23rd August, 2018)
  17. #13
    Dec 2013
    London
    most paid channel not working any more on satellite boxes, v8s etc. try web tv. but you need valid subscription
