if its not listed i wouldnt try mate unless you want a fried mcu
is it cas4 ?
dave
is it cas4 ?
dave
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
Smok PSA, volvo & ford
If someone helps you DONT FORGET TO SAY THANKS its only polite....
hello
mask 3m25j
what # is listed on smoke?
fruti (28th May, 2016)
You cant read it with smok . Use Xprog-m for that mask
Sent from my SM-G925F using Tapatalk
hello , this one frm of bmw not cas4
Hello
Xprog 5.55 read and write mcu mask 3m25j
HOLA
Or UPA USB !
Today I read one FRMIII .
Everything will be okay!
Hi mates. I have problem with mini frm3. I cant read with smok but I cant erase and write. After erase or write when I read it (ee, flass or s-flash) always is the same info. I tried with orange and it make well. Can anybody help how I need to do with smok? and other question. Which are the steps to fix well frm3 because I have ee fixed but when I put it in car the problem still there.
Thanks in advance
alclot (24th January, 2018)
Hello!!
I try read 9s12XEQ384 flash file and it goes ok with x-prog but eeprom it canīt read even if i reset security. What iīm doing wrong?
vvdi prog can read it
Smok read and write FRM
