Results 1 to 4 of 4
    Apr 2016
    GT
    Unhappy EEPROM memory and crystals
    someone could explain because you put a bridge to the crystals for programming the EEPROM.
    As what the crystals?
    I want to learn to program them only with a clip eeprom, and I do not want desoldering memory.
    thank you very much.
    Moderator
    PremierD's Avatar
    Jun 2009
  3. The Following User Says Thank You to PremierD For This Useful Post:
    MV auto (25th May, 2016)
    Rerouter's Avatar
    Jul 2014
    Australia
    The crystal, or "quartz crystal oscillator" is the clock of the device that would normally talk to the eeprom,
    By shorting it out you prevent that device from waking up, for most devices this leaves most of its pins "open circuit" allowing you to read the eeprom without it interfering,
    There are 4 main types, 2 pin crystals, 4 pin crystals (both tend to be in the silver package), resonators, and clock drivers,
    the 2 and 4 pin style can be shorted, or if in doubt use a 100 ohm resistor, resonators must only be shorted by a resistor, and clock drivers cannot be touched, instead you would look for the devices reset pin.
  5. The Following 6 Users Say Thank You to Rerouter For This Useful Post:
    alexander1983 (2nd February, 2024), Berubeg (26th May, 2016), H2Deetoo (26th May, 2016), MV auto (25th May, 2016), neospeedo (26th May, 2016), zckariya70 (31st May, 2016)
  6. #4
    Jan 2013
    if you do incircuit/onboard pogramming of eeproms, have always to short crystal.
    eeproms like 25xxx and 95xxx you can read/write for sure without destroying data
    but for other eeproms it is always better to desolder it and then to do the job
    (to avoid the data to be damaged through reading process)
  7. The Following 2 Users Say Thank You to rocko For This Useful Post:
    Berubeg (26th May, 2016), MV auto (25th May, 2016)
