Results 1 to 14 of 14
    Sep 2010
    Default A780 help please
    Apologies if I've missed it I've downloaded new ware (I think ) got the old Kryptview loader tryed to flash and it says port 1 check to parameters ?? Is there a tut on this new one been at this all day and getting no where fast thanks
    Sep 2008
    i bet you not change from com port 1-2-3-4 on the loader and should work then,hiteck has a kv flashing guide
    Sep 2010
    I tryed all coms from 1-4 but same message ??
    Sep 2010
    Still can't get this to work I've got the loader from dk download and got the kva78023/5/2016 from somewhere else unzip them with winrare . I have tried this on 2 laptops and get ( cannot open portcom1 please check if the com pet has the following parameters . Baudrate;115200bps/parity no parity /databyte 8bit/data I've been getting same thing for days any ideas thanks
    Sep 2010
    Sorted needed to find drivers
    Quote Originally Posted by ack1234 View Post
    Hello How u sorted that for me also same message ,can u give some idea mine is port 5 but it says download not requested...
    Sep 2008
    boxes are better flashed with old xp pc/laptop with a rs232 port then connect null modem cable,have box powered off at rear press download and power on box all mentioned on the guides one suppose to have read.
    Sep 2010
    Mine also said that just press ok and then the start button again
    but mine says download not requested.....
    Apr 2008
    leave krypt off then once you have selected file to send then turn box on
    Quote Originally Posted by delboy13 View Post
    Nothing helping ... I am using null cable with usb end (one side) is that matter....?
    Apr 2008
    never used usb one myself, there must be someone on here who's uses one of them. maybe you need to install drivers for cable
  13. #13
    I haven't install drivers for cable but its showing us port 5.... when I connect to computer.... n trying to send file to port five through loader but it says download not requested...
  14. #14
    sounds like wrong cable.
