Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    To synch steering lock, go to the menu in TEchstream and you will see it there. Its called a handshake, usually the second info on the left when you open Utility tab on Smart ecu tab
    Sent from iPhone 4S
  2. The Following User Says Thank You to sogaro For This Useful Post:
    luis12 (15th August, 2016)
  3. #17
    luis12's Avatar
    Jan 2011
    Panama
    Friend finally and after try with lots of dumps and expensive tools like...Orig AVDI, orig Tcode, org MVP pro, and others scanners solved with and old cracked Techstream versi?n, Tango Techstream calculator and cheap Xhorse Mini VCI interface ($27)... job done in 20 minutes, incredible but true still cant believe. A 2015 car Lexus all keys lost... everyday learning.
  4. The Following User Says Thank You to luis12 For This Useful Post:
    ucokseparoh (16th August, 2016)
  5. #18
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    Quote Originally Posted by luis12 View Post
    ....solved with and old cracked Techstream versi?n, Tango Techstream calculator and cheap Xhorse Mini VCI interface ($27)... job done in 20 minutes, incredible but true still cant believe. A 2015 car Lexus all keys lost... everyday learning.
    Congratulation.
    was it done with the original files or with files after reset?
  6. #19
    luis12's Avatar
    Jan 2011
    Panama
    Quote Originally Posted by ucokseparoh View Post
    Congratulation.
    Must be reseted with original files because Techstream process not only Smart also Steering lock and ID box, also calculation is individual to VIN.
  7. #20
    Nov 2012
    Quote Originally Posted by aketokediag View Post
    Hello M8,
    Write this dump to your smart key, same pass as before.
    I can get the password for LEXUS SMARTBOX VIRGIN
    I have the same smart box 89990-53013
    thank you
  8. #21
    Nov 2012
    thank you
