Openbox v8s firmware problem
Results 1 to 15 of 17
    Jun 2016
    Default Openbox v8s firmware problem
    I have just been given an openbox v8s and i was told i would need too put the latest firmware on it but everytime i try too update by usb it says hardware mismatch. Can somebody point me in the right direction please as i am new too this thankyou
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Sounds like the wrong firmware, try the firmware available from skybox.cc
    Jun 2016
    thanks for the quick reply, i have tried a few now but all i get is hardware mismatch when trying to upgrade by usb
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Try the firmware P&D provides in this thread, post #5
    http://www.digital-kaos.co.uk/forums...61-v8s-problem
    Jun 2016
    already tried doing that by following his instructions and still says hardware mismatch, i thought it was my usb so i checked and its not that as its formatted to fat32. i have tried everything and running out of ideas
    P&D's Avatar
    Silly question but I have to ask......Are you unpacking the file to the usb ?
    So the file on the usb is a .abs file & not a .rar file ?
    Jun 2016
    yes its an abs file that i have been trying too upgrade it by
    Mar 2014
    I have the same issue, my firmware on the the box i just got is 3511HD_30_09_2015_0326
    I have tried a couple of different firmware and all i get is harware mismatch.
    Do you need to rename it ? or does that make a difference
    I too have made sure its the .abs file
  9. The Following User Says Thank You to Aveeno For This Useful Post:
    tatieasi (1st January, 2021)
  10. #9
    Jun 2016
    I have the same issue, did you guys resolve it?
  11. The Following User Says Thank You to myaqub For This Useful Post:
  12. #10
    Jun 2016
    Hi, I have found the correct firmware for these boxes if you still require it.
  13. #11
    yes please if you have the right firmware for the V8s Openbox.
  14. The Following User Says Thank You to fox1562 For This Useful Post:
  15. #12
    digicon's Avatar
    No need for any external links download sites can easily be found with Google, Or simply just attach firmware to your post.
    OP try one of these:
  16. The Following 5 Users Say Thank You to digicon For This Useful Post:
    ajhassan (30th August, 2016), ardasa (16th November, 2016), jairo42 (20th February, 2021), monkeyboy600 (15th February, 2017), tatieasi (1st January, 2021)
  17. #13
    Nov 2016
    Hi. and on the openbox v8se have firmware that worked PowerVu keys?
  18. #14
    Member 1888's Avatar
    Oct 2016
    East Lothian
    Related ish. I was making a bootable USB drive to install linux in a PC with no CD-ROM. It all went well and would not work in the computer. USB showed up as fine and dandy when checked but decided to tray another anyway. Worked first time so might be worth using another USB stick if you are having problems. Do USB have data transfer rates like a SD card? Could be the problem.
  19. #15
    Apr 2013
    LINK REMOVED this is the correct place to get firmware for open boxes
    but a new version will be available next week
    Last edited by digicon; 30th June, 2017 at 09:21 PM. Reason: Please attach files no Links to Shops
  20. The Following 2 Users Say Thank You to edd937 For This Useful Post:
    jairo42 (20th February, 2021), tatieasi (1st January, 2021)
