hi.
does A6 2016 works with smelecom?
thnx.
hi.
thnx.
honingkoning (5th May, 2017)
I have done 2016 A6 with smelecom no problem
Update 05/03/2017(version:0397.06a4) ODOMETER: ROEWE / BSI-ROEWE 360 (95160) by EEPROM TOYOTA / YARISL 2012 (93C66) by EEPROM TOYOTA / PRADO 2011 (93C86) by EEPROM TOYOTA / VTIZ (93C66) by EEPROM TOYOTA / PRADO 2016 (93C86) by EEPROM MERCEDES / ODOMETER (95128) by EEPROM PEUGEOT / BSI- 308 (95128) by EEPROM PEUGEOT / BSI- 308 2016 (95128) by EEPROM LEXUS / LX570 2016 (93C86) by EEPROM CHINESE CAR / BEIQISHENBAO-BCM(95320) by EEPROM CHINESE CAR / BEIDOUXING (93C46) by EEPROM CHINESE CAR / GUANGQICHUANQI GA5 (24C32) by EEPROM CHINESE CAR / DONGFENG DX5 (24C32) by EEPROM CHINESE CAR / JIANGLINGYUSHENG (93C86) V2 by EEPROM CHINESE CAR / SHANQIDELONG (9S12XHZ256) by MOTOROLA CHINESE CAR / BEIQIFURUIDA (24C04) by EEPROM CHINESE CAR / BEIQIWEIWANG (24C04) by EEPROM CHINESE CAR / JILIYUANJING X6 (24C04) by EEPROM CHINESE CAR / MINGJUE5 (95080) by EEPROM CHINESE CAR / BSI-MINGJUE3 (24C16) V2 by EEPROM CHINESE CAR / CHANGAN CS75 (9S12XHZ512) by MOTOROLA VOLVO / XC60 2014-UP V1 DIAG by OBD2 VOLVO / XC60 2014-UP V2 DIAG by OBD2
alle bmw (14th May, 2017)
Any one have success with honda accord 2014 93c76 and up with dsp3
to read and wright new miles?
with out damege the cluster ?
thank you
It seems to work only if we remove the eeprom. We have tried several 13-16 accords by using a pinout in the back and reading the eeprom in-circuit with a dspIII+ and it corrupts the dump. Problem is to get to the chip.. those steppers are tough.
never had an issue , i have done over 12
Reading is fundamental, asking is easy............................
in circuit from the rear pinout (without removing steppers)?
You cant remove the needles on this car
that is the problem.
that why i am ask if some one did with out the problem.
some members report they did from rear points with out any problem
sone say dash its dead after reading.
Hello guys ,
need to know if it's possible to buy a smelcom in Algeria with a good price
Every time we try to read one the dash is dead. Bad dump using rear pinout. I will say that the USA version 2013-2016 accord is a different board than what smelecom has on their programmer. The picture is different. It is still a 93C76 but the pic is different.
Some one have power up conection
for Honda acoord 2013 and up?
5 ground
32 positive
rukartinatv (7th May, 2017)
Smelecom use acoord usa pdf that for sure
i use this pdf with another programer and all work
why you say its diferent?
