Page 28 of 62 FirstFirst ... 18232425262728293031323338 ... LastLast
Results 406 to 420 of 930
  1. #406
    drpeter's Avatar
    The Netherlands
    I tested the smelecom F10 km stopper works perfect, don't need to activate again everytime you start the car. All functions work fine.
  2. The Following User Says Thank You to drpeter For This Useful Post:
    Hayssam1 (16th October, 2017)
  3. #407
    Mar 2011
    EU
    I have some problem with my data smart some days ago, I tried some audi a3 year 2009 2005 2007, i always have "failed to initialize can or failed to reveived data. I tried several Times , one time ds3 can conect but killed dash and I must repair with smok.
    Someone have this problem ?
    Envoy? de mon iPhone en utilisant Tapatalk
  4. #408
    Mar 2017
    I have been using Smelecom KM Freezer for W222. I removed the freezer but the problem is that the Range (Distance To Empty) is inaccurate. When I fill up the tank, it reads 200km, however, I drives up to 550km+ without refueling. I would like to know how to fix the issue. Would resetting to factory setting from Dash fix the problem ?
  5. #409
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by aialmarz View Post
    Yes just try reset or battery disconnect
  6. #410
    Mar 2017
    Quote Originally Posted by teerak2uk View Post
    I tried resetting to factory settings but it didnt help. I tried to locate the battery in the trunk but could not find it. I own 2017 S500 coupe. Where is the battery located at and whats the easiest way to do a battery disconnect?
  7. #411
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    2017 take it to dealer its under warranty
  8. #412
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    Update 08/02/2017(version:0305.0027)
    ODOMETER:
    MOTOCYCLR / NC700 (24C04) by EEPROM
    HONDA / ACURA MDX 2014 (93C66) by EEPROM
    NISSAN / PICKUP 2014 (93C86) by EEPROM
    NISSAN / MARCH 2013 (93C86) by EEPROM
    PEUGEOT / BSI- 308 (95256) V2 by EEPROM
    PEUGEOT / ODOMETER- 4008 (95320) V2 by EEPROM
    PEUGEOT / BSI-4008 (95128) by EEPROM
    PEUGEOT / BSI-5008 (95128) by EEPROM
    PEUGEOT / ODOMETER-5008 (95160) by EEPROM
    CITROEN / BSI - C4 (95256) V2 by EEPROM
    CITROEN / ODOMETER - C4 (93C86) by EEPROM
    FORD / F450 2011 (93C86) by EEPROM
    CHINESE CAR / FUTIANAOLING (24C04) by EEPROM
    CHINESE CAR / ZHONGTAI X7 (93C86) by EEPROM
    TOYOTA / AVANZA 2016 MB91F061BS by BCM2
    TOYOTA / AVANZA 2016 MB91F061BS(WRITE FLASH) by BCM2
    MAZDA / CX-5 DIAG by OBD2
    FIAT / TORO 2017 DIAG by OBD2
    CHRYSLER / COMMANDER 2017 DIAG by OBD2
    FORD / MKZ 2017 DIAG by OBD2
    AIRBAG:
    FIAT / PALIO STRADA 2013 51920997 by EEPROM
    Reading is fundamental, asking is easy............................
  9. #413
    Jul 2011
    I have got problem with my SMELECOM Data Specialist Plus with activation. Today I pluged device to the car and smelecom machine report me caution, that I need to activate within 3 days machine. OK, I have installed PC-LINK soft to my PC, but I cannot connect my PC with SMELECOM machine. Cannot instal driver succesfully, I have tried 32bit and also 64bit, but always with error. Can somebody help with driver instalation for PC LINK?
    Thank you,
    regards
  10. #414
    XmoDDeR's Avatar
    Mar 2011
    Quote Originally Posted by immooff2 View Post
    Thank you,
    regards
    that means u have 3 days till you have to use active function, its for security
    who is your dealer
    and if touchscreen it doesnt use pclink
  11. #415
    XmoDDeR's Avatar
    Mar 2011
    new update tonight or tomorrow? depends on dinner
  12. #416
    Sep 2013
    Take out immbox and read eprom do it as Magotan is Passat in china ,no possibile thru obd
  13. The Following User Says Thank You to holbi1 For This Useful Post:
    highrisk (19th September, 2017)
  14. #417
    XmoDDeR's Avatar
    Mar 2011
    Hmmmmm i smell vw today or tomorrow, same options . Works
  15. #418
    XmoDDeR's Avatar
    Mar 2011
    Update 09/18/2017(version:0305.0027)
    ODOMETER:
    VW /(NEC+24C64) 06.2014- DIAG by OBD
    AUDI /(NEC+24C64) 06.2014- DIAG by OBD
    SEAT /(NEC+24C64) 06.2014- DIAG by OBD
    SKODA / NEC+24C64) 06.2014- DIAG by OBD
    IMMO:
    VW 4TH IMMO SYSTEM / (NEC+24C64) 06.2014-
    KEY ADAPTION
    by OBD2+TRANSPONDER
    AUDI 4TH IMMO SYSTEM / (NEC+24C64) 06.2014-
    KEY ADAPTION
    by OBD2+TRANSPONDER
    SEAT 4TH IMMO SYSTEM / (NEC+24C64) 06.2014-
    KEY ADAPTION
    by OBD2+TRANSPONDER
    SKODA 4TH IMMO SYSTEM / (NEC+24C64) 06.2014-
    KEY ADAPTION
    by OBD2+TRANSPONDER
  16. #419
    SEAT.'s Avatar
    CAPE TOWN
    what is this update about when u look at the cars added it old siht
  17. #420
    Mar 2016
    Likely shaking the bugs out, I suppose.
