Page 39 of 62 FirstFirst ... 29343536373839404142434449 ... LastLast
Results 571 to 585 of 928
  1. #571
    Nicolas9's Avatar
    Feb 2017
    Aruba
    hi
    does smelecom do w212 facelift without filter?
  2. #572
    Sep 2013
    Today I got strange thing with 2012 lost key seat leon. When i write bin mode nec 64 odometer was blinking and the display was black and white cant write transponder .Cant do nothing seriouslly is a crap tool for keys .So I write back original dump and clluster back to the life but still no service mode .I never used this for tacho but for keys is ....
  3. #573
    Nicolas9's Avatar
    Feb 2017
    Aruba
    just had 2x Audi a7.
    with dsp+.
    first a7 2015 obd ok.
    second a7 2015 failed to receive data..
    I tried a few times. no luck
    any tips?
  4. #574
    hass42's Avatar
    Aug 2012
    USA
    Quote Originally Posted by Nicolas9 View Post
    with dsp+.
    any tips?
    What's the build date of the second Audi A7?
    I am very surprised you were able to do first one ...
    Hass42
  5. #575
    Nicolas9's Avatar
    Feb 2017
    Aruba
    don't know.
    but I also did a6 2016 before.. same type cluster
  6. #576
    Quote Originally Posted by hass42 View Post
    Hass42
    Why would you be surprised?
    Sent from my SM-G950F using Tapatalk
  7. #577
    hass42's Avatar
    Aug 2012
    USA
    Quote Originally Posted by javyb View Post
    Because I have tried 3 different ones and they never worked that year.
    I guess being built after 6/14 it's not going to work, is what I am told anyway.
    And I don't see many vehicles built that early for next year's production.
    Hass42
  8. The Following User Says Thank You to hass42 For This Useful Post:
    Nicolas9 (21st April, 2018)
  9. #578
    Hass42
    I've done 2016 a7 and 2017 A6 no issues so I put it down to user error
  10. #579
    hass42's Avatar
    Aug 2012
    USA
    Oh shoot.... I am so sorry guys. I am mistaken it was a A5 that I wasn't able to do. I tried like 3 of them in the past year.
    My mistake.
    Hass42
  11. The Following User Says Thank You to hass42 For This Useful Post:
    Nicolas9 (23rd May, 2018)
  12. #580
    tried a 65 plate audi a1? same as q3 unknown version 0064?
  13. #581
    Nicolas9's Avatar
    Feb 2017
    Aruba
    @hass42: thnx for reply. mistake can happen. but now I now a7 2015 should normally be possible.
    @ v-diag: with x-tool i also cannot do this sw 0064. i think only with smok or better tools like dp4
  14. #582
    [QUOTE @ v-diag: with x-tool i also cannot do this sw 0064. i think only with smok or better tools like dp4[/QUOTE]
    all tools work the same with the latest vag 2014+
    they all have the same software.
  15. #583
    Oct 2017
    Hello has anyone here had problems with dsp3's obd adapter? I read a thread that was the similar problem so I'm wondering if other users had the same issues. My dsp3 won't power up through the obd adapter it will make a buzzing sound kinda like a relay rapidly turning on and off and the screen will flicker but no power. This has rendered my machine useless with the obd function making a 5 min job 30+ mins. Help desk said to replace the power jack see attached pic. I did it but didn't change a thing. Other than obd function not working machine powers up fine any other way and works good with other adapters. If anyone have any ideas on what it is I'd appreciate it
    Sent from my SM-N950U using Tapatalk
  16. #584
    Oct 2017
    Quote Originally Posted by esx503 View Post
    Update replaced the connectors twice and still doing the same thing just in case someone is going through the same issue, buzzing is gone and it now powers up through obd it powered up and stopped buzzing on it's own without me having to replace anything. Steps 4 5 and 6 of the obd adapter read 0 volts. Will update once I know more.
  17. #585
    Oct 2017
    Problem was obd adapter just as I had suspected. A piece of it had fell off of it. Had to buy another circuit board
