Page 41 of 62 FirstFirst ... 31363738394041424344454651 ... LastLast
Results 601 to 615 of 929
  1. #601
    May 2015
    Hass 42 you have try on gmc truck? Change hours also? Stand by review to order fpcb
  2. #602
    hass42's Avatar
    Aug 2012
    USA
    Quote Originally Posted by Berubeg View Post
    Yes hours, idle and odo
    Hass42
  3. The Following User Says Thank You to hass42 For This Useful Post:
    Berubeg (5th August, 2018)
  4. #603
    Jun 2016
    How did you do it?
    I have installed the FPCB board and I never get asked for any code.
    I just tried 2017 Suburban and comes with error
  5. #604
    Mar 2016
    To clarify, have you downloaded and installed the code file folder and installed all current firmware and software updates?
  6. #605
    Jun 2016
    Firmware and software was up to date.
    I didn't know that I had to download the code.
    I just did and will try it again soon
  7. #606
    Jun 2016
    After downloading the CODE folder to the SD card it appeared that everything will be ok.
    While programming the new mileage this message popped up :
    Quote Originally Posted by dimitrebg View Post
  8. #607
    Mar 2016
    Double check your soldering per the PDF supplied. Also, for the cost of airmail, I bet Smelecom would have to back and forth with a repair in a week's time.
  9. #608
    Ireland
    Is it ok to offer a Smelecom for sale here?
    It's my own kit ...I'm not a reseller.
    Pager.
  10. #609
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    2005 Kia Sedona. Just wondering something real quick. I'm trying to set it. I programmed it in KM and it the cluster reported KM so I gather if I set it in Miles it'll read in miles? I only ask because I've set most kia's with KM and it appears as miles in the cars.
  11. #610
    DK Veteran kams20040's Avatar
    hi friends there is and issue with vagprog for audi a3 8v MQBAB .... year 2013
    i know its possible for audi after 2014 but for 2012-2014 i dont know .....
  12. #611
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by kams20040 View Post
    No works good. If you have the nec35 software activated.
    And if keyless go then first put on contact, then remove battery from key, then hold key to side of steering wheel
  13. #612
    honingkoning's Avatar
    Dessert
    What issue if sw version is known it should work.
    But my experience is not that good, to much versions do not work 2012/2014.
    Smok Seams to work great for this models.
    Wbr
  14. #613
    Dec 2017
    It could possibly Johnson’s Software
    Which is not possible from 2012 onwards till
    Now
  15. #614
    Nicolas9's Avatar
    Feb 2017
    Aruba
    A3 doesn't have Johnson. And I never had problems with smelecom
  16. #615
    Quote Originally Posted by Nicolas9 View Post
    MQBAB???????
