lesther1702 (6th October, 2021)
I tried same vehicles with another tool
gave security access and write km ok
but nothing was changed in the eeprom
in the end i took speedo out and did it manually with brain.exe
dave
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
Smok PSA, volvo & ford
If someone helps you DONT FORGET TO SAY THANKS its only polite....
Random thought. I thought the Jaguar would have been part of the USA prog or at least part of the US versions of cars. So why was it excluded in the package? Any input would be nice. Thank you
RS3 2016. Obd Ok
weza247 (2nd January, 2018)
it is possible change mileage on audi A6 2016 year with this update: Option 48 Software Add on for TOUREG 10-UP, A6 12-UP, A7 10-UP, A8 10-UP, MULSANNE 12-UP OBD ?
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
I tried golf7 from end may 2014, not sure if it is old or new version.
Few months back I tried this car. With nec35 2014 software. I was broken but couldn't do it, I said to contact supplier for new software.
Now I tried with new mqb 6/2014- software.
First time it said something like cannot get access. For second try it said '8888.
Failed to receive ACK'.
(The battery in key was low but I don't think it matters).
Then I tried again with old nec35 software. Then it said Cannot access work more.
Any help please?
Thnk you very much, I don't know what to do.
It was software 2210
I have question about Volvo xc60 2012.
Do I need to choose option xc60 mileage correction. Of xc60 mileage synchronisation? (Or both)
This Volvo has active cem module.
To program lets say 2010 Mazda CX7 do we need the original cluster to program a new cluster to a vehicle? Need to get this clarified. To my disliking I'm getting this all the sudden. Anyone else?
Edit:
Update 09/22/2015(version:0349.061d) ODOMETER: MAZDA / MAZDA CX7 10-UP DIAG by OBD2 MAZDA / AXELA 2015 DIAG by OBD2 MAZDA / MAZDA 3 2009-2013 DIAG by OBD2
These were released over 2 1/2 years ago almost. Is anyone going to look at this? I did run a system update, firmware update, and still. Same problem. Anyone have any insight?
Last edited by tfourk; 12th January, 2018 at 09:09 PM. Reason: Adding picture with error
Smelecom can do w222 nu obd without filter. But I read is had problems, best to do use a filter to be safe.
Any news about it? Thnx
Well the CX5 and CX9 load fine for the mazda for OBD programming. But CX7 does not work at all. Any Smelecom staff going to address this? I don't want to send a "dump file" I'd like to use my equipment how it's suppose to work.
