Page 3 of 63 FirstFirst 123456781353 ... LastLast
Results 31 to 45 of 931
  1. #31
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    got tool in august 2015 , v2 vue added 2 months ago if that long
    Reading is fundamental, asking is easy............................
  2. #32
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by XmoDDeR View Post
    I don't care what you say atm.. I know what I saw and I know I tried both version when it was black. don't work obd anyways...now they saying hey if you buy the option you still wont be able to do it w/o taking out bcm...makes no sense at all why any one would even buy the option to do obd when its not possible w/o talking out bcm... If we have to take out the bcm then might as well do direct onboard or mpu....THE END!.
  3. The Following User Says Thank You to FxShaw For This Useful Post:
    Plcautoparts (15th June, 2016)
  4. #33
    XmoDDeR's Avatar
    Mar 2011
    ......................funny guys there are a lot of ways ways to use obd on the bench i use that all the time if you have donr that bcm u would rather use obd bridge than solder internal
  5. #34
    May 2015
    Someone try 2015 grand Cherokee srt8 with smelecom.
    Need clean job because engine dead....
    thank's friends
  6. #35
    hass42's Avatar
    Aug 2012
    USA
    Quote Originally Posted by Berubeg View Post
    thank's friends
    I have done a few with different engine packages. No problems
    I don't think engine is a factor
    Hass42
  7. The Following User Says Thank You to hass42 For This Useful Post:
    Berubeg (16th June, 2016)
  8. #36
    May 2015
    You could make sri? Not possible to read... And you say for engine hours
  9. #37
    hass42's Avatar
    Aug 2012
    USA
    Sri is possible by obd, and I never read hours on this vehicle, I don't think
    Hass42
  10. The Following User Says Thank You to hass42 For This Useful Post:
  11. #38
    May 2015
    Not work for sri with smelecom on this vehicule. Not say if because it's srt8
  12. #39
    XmoDDeR's Avatar
    Mar 2011
    it works fine
  13. #40
    hass42's Avatar
    Aug 2012
    USA
    Yes it does
    Hass42
  14. #41
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Any experience with
    BMW CAS/CAS2/ CAS3 / CAS3+ BY OBD2 ????
    Most interested in me for Mini Cooper , Countryman ....because removing cass is
  15. #42
    Sep 2009
    Quote Originally Posted by cokolo View Post
    Any experience with
    Cas2 good by cas plug. Cas 3 some version by dash plug. Cas3+ by obd dont work
    Sent from my SM-G935F using Tapatalk
    Don't forget to hit thanks button
  16. The Following 2 Users Say Thank You to javyb For This Useful Post:
    cokolo (21st June, 2016), super jumbe (22nd June, 2016)
  17. #43
    hass42's Avatar
    Aug 2012
    USA
    I was doing 2016 Ford F-150 with 4" display yesterday.
    After reading it shows 0 for current mileage.
    I updated miles to where I needed anyway and worked.
    So just a FYI if you run into this issue.
    Hass42
  18. The Following 2 Users Say Thank You to hass42 For This Useful Post:
    Berubeg (23rd September, 2017), javyb (29th June, 2016)
  19. #44
    Dec 2009
    No cas 3 after about 2011 will go obd because of bmw security updates
  20. #45
    Sep 2009
    Quote Originally Posted by diagtech View Post
    No cas3+ 2007 up will go obd with smelecom full stop
