Help immo off please Toyota 4runer 2000 Thanks in advanve
Some cars not work in Smelecom sw. 6/2014 MQA and tool show Run time error .Someone have this problem.We have in VW Polo and Golf7.
hi.
i did a Volvo v40 2013. worked good.
then I read error with Delphi.
in instrument cluster there is now error 'manipulated odometer - permanent.
I cannot delete it.
someone has a good tip for this?
Burn the Vehicle ....
cokolo (27th March, 2018), dashradio (27th March, 2018), lupu_sandu (27th March, 2018), XmoDDeR (28th March, 2018)
Good Evening Guys,
Im having a Big trouble connecting my DSP3+ To my New laptop (windows 7 Not so new). and when I connect the device with the Driver Installed It Says that cannot Initialize the Device (shows the Yellow Sign on the Device on the Device manager). and I have couple Ideas: 1. My Com Setting on the DSP is Wrong
About the Connection:
NAME: MY CONNECTION
DEVICE: .MX28 COM1 UNIMODEM
PORT SETTINGS AS IT FOLLOWS:
MANUAL DIAL: DISABLED (UNCHECKED)
TERMINALS: BOTH DISABLED (UNCHECKED)
BAUD RATE: 19200
DATA BITS: 8
PARITY: NONE
STOP BIT: 1
FLOW CONTROL: HW
Or I'm Doing something wrong on the Step by Step Setup on my laptop, So any clue would be really appreciated, since now I'm starting to panic
Thanks before Hand, Rick
Make sure you have set up Microsoft device manager (Active Sync) correctly. Smelecom has good customer service via Skype.
I once had same kind of problem with smelecom datasmart. probaly the same could happen to dsp3..
you need to make sure the tool knows it's connected to the pc. otherwise the computer cannot find the tool!
i dont know exactly which buttons you'd have to click.. but look for update or pc connectin button or menu item. when it shows an image that you can connect the pc, then the pc will find the connection and install drivers..
Good Afternoon Morrisgauge,
I got connection changing the DEVICE: .MX28 COM1 UNIMODEM --> COM08
and the Device reacts to it, but then doesn't completes the connection so I would like to know if anyone has a screenshot of the connection so i can emulate that setting on my DSP
has anyone done 2015 VW Jetta with usaprog??
DON'T JUST SAY PRESS IT.....
Friends Seat Leon 2013 lost keys is nesesery to take out the cluster? or can do as istruction says via obd NEC64KEY.bin is for the following options SEAT M2 2013(DIAG) I do this firs time.
holbi1 (9th April, 2018)
Today I try with datasmart immo Audi A 1 2012 can't write transponder failed . Somebody can Help.
So you mind put it in this small hole because i try with transponder in key and in key adapter .
