Page 1 of 62 1234561151 ... LastLast
Results 1 to 15 of 928
    Dufner
    Johnner's Avatar
    Éire
    Default ***** SMELECOM SUPPORT THREAD *****
    Opening this thread to facilitate people's questions,queries about Smelecom
    2x things : 1. No advertising/promotion of developers/resellers
    2. No discussion about prices whatsoever !
  2. The Following 18 Users Say Thank You to Johnner For This Useful Post:
    CLK1201 (9th June, 2016), clusters (7th June, 2016), DashProg (7th June, 2016), goosebartek (25th November, 2016), jarbo3a (5th October, 2016), masterb (8th June, 2016), mouaoued122 (10th July, 2016), MV auto (7th June, 2016), neospeedo (21st July, 2016), pongsky (28th October, 2023), PremierD (8th June, 2016), shirokov (7th June, 2016), solitaire (29th April, 2017), super jumbe (7th June, 2016), vasa (9th June, 2016), violator11 (27th November, 2016), XmoDDeR (10th June, 2016), zckariya70 (7th June, 2016)
  3. #2
    super jumbe's Avatar
    Livingstone
    I always use smelecom dash tools, tools never let me down, new updates regularly on line.
  4. The Following 7 Users Say Thank You to super jumbe For This Useful Post:
    Carsoft2003 (25th December, 2018), DashProg (14th June, 2016), Demetrius (20th January, 2017), digidashaustralia (18th March, 2019), Johnner (7th June, 2016), maruti (28th August, 2016), weza247 (12th December, 2017)
  5. #3
    Dec 2010
    How is your experience with eeprom
    read and wright on the board
    with dsp3?
  6. The Following User Says Thank You to rukartinatv For This Useful Post:
    mhedz (4th September, 2021)
  7. #4
    Quote Originally Posted by rukartinatv View Post
    with dsp3?
    Very good to read and write in circuit
    Sent from my SM-G935F using Tapatalk
  8. The Following 2 Users Say Thank You to javyb For This Useful Post:
    DashProg (14th June, 2016), stutar (14th November, 2021)
  9. #5
    I have dsp3 reading chip on board is not so good.80 percent wont work, I have change 2 eprom adepters and upgrade my tool to dsp3 from old usa prog.after every 15 days it needs to actvated .it just start happening recently
  10. #6
    Quote Originally Posted by cklair View Post
    What chip types you having problems reading on-board
  11. #7
    batandball's Avatar
    May 2011
    Some times if it wont read, voltage can be too low, up the voltage abit
    If it works use it
    BatandBall
  12. The Following User Says Thank You to batandball For This Useful Post:
    MileageAudit5 (15th September, 2019)
  13. #8
    smartymarti's Avatar
    Jan 2011
    cornwall
    i find it a good little get out of jail tool helped me out a good few times , updates for the eprom side are slow but they get there in the end
    All about the Bass
  14. #9
    In EEP
    new tool same problem not read in ciruit 25...95... i try high voltage but same with 93C..not problem
  15. #10
    Quote Originally Posted by vasa View Post
    Check your eeprom clip is connecting properly. I manage to read all in circuit fine
  16. The Following User Says Thank You to javyb For This Useful Post:
  17. #11
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Visteon dash don't work
    Edc 15 some time work some time not work (5/10)
    Edc 16 it's support very little edc16xx (3/10)
    Seat Leon 2012-2014 VDO (1/3)
    Audi A4 2009 after 15 minutes waiting and turn ignition off nothing happens? ??
    After 6 month used when trying to update interface is blocked and must sent to China and 20 days without interface and cost me lot of money and lot of clients(of course thanks to my distributor that time would be longer) . Problem is in interface software problem .
    That's my experience with Smelecom
  18. The Following User Says Thank You to cokolo For This Useful Post:
    scanner_man (2nd August, 2016)
  19. #12
    Quote Originally Posted by cokolo View Post
    Never had issue with Leon 12-14 works perfect
    Audi a4 2009 can be tricky if not been done before as CAN system goes to sleep. Keep heaters lights on and should go fine
  20. The Following 3 Users Say Thank You to javyb For This Useful Post:
    Demetrius (20th January, 2017), jarbo3a (5th October, 2016), zoom69 (18th June, 2016)
  21. #13
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Quote Originally Posted by javyb View Post
    What about Visteon, EDC 15, EDC 16 does it work? Or maybe I don't know how to press button on Smelecom ☺
  22. The Following User Says Thank You to cokolo For This Useful Post:
  23. #14
    Moderator
    PremierD's Avatar
    Jun 2009
    ................. You're alive .............
  24. The Following User Says Thank You to PremierD For This Useful Post:
    super jumbe (12th June, 2016)
  25. #15
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Quote Originally Posted by PremierD View Post
    Very very alive ��
  26. The Following User Says Thank You to cokolo For This Useful Post:
