    Aug 2011
    Default Motorized Dish with DM800HD !!
    Hello friends,
    Can i use Motorized Dish with DM800HD pvr and do move the dish with receiver ?
    It will be appreciated if got the right answer.
    digicon's Avatar
    Yes you most certainly can either suing USALS or Diseqc 1.2
    Aug 2011
    I set the Motorized Dish and its not moving the Dish when i change the channel from one satellite to another degree !!
    Could you be more specific ?
    digicon's Avatar
    If your using USALS to move your dish then you need to setup the tuner configuration in the menu to simple - positioner and then fill in your Longitude and latitude details for your area
  5. The Following User Says Thank You to digicon For This Useful Post:
    fahimjan (5th July, 2016)
    Aug 2011
    I changed it to the "Simple" and the A position is Hotbird 13e and the B position is Eutelsat 9e , but, the Position-er option doesn't seem to be working and it says like this:
    No tuner is configured for use with a diseqc position-er
    Jun 2016
    In settings you have to change in the settings to Diseqc 1.2 or USALS how digicon said. If you use Diseqc 1.2 you have to move the dish manuel with the receiver and store the positions for every satellite in settings. If you use USALS you have to setup your dish on the right way how its explained in the manuel.
