Results 1 to 7 of 7
    May 2011
    Default How do I flash using Windows 10?
    Hi folks been a long time since I've done this and onto a new laptop what do I use to flash the box using my cable etc I'm not sure how it's done and with a new laptop is it possible ? Thanks
    Nov 2012
    GB
    Check the top post firmware loading guide for krytview
    Sent from my SM-G900F using Tapatalk
    May 2011
    Yes I have looked on there but the kryptview loader file says oops not working ? Any idea what I use as a loader ?
    Nov 2012
    GB
    What krytview are you useing
    May 2011
    A780. Is the box I have
    Nov 2012
    GB
    The loader and the latest .bin file for the kv780 should be in the downloads section on the forum
    Junior Member alano's Avatar
    Oct 2010
    Hi folks, the software wont work directly on windows 10(well I couldn't get it to work) I was able to run the software on a windows 10 PC in compatibility mode for windows xp service pack 3, loader and bin file worked fine on com port 1 which was automatically selected by the software.
    hope this helps y'all out
