Page 118 of 169 FirstFirst ... 1868108113114115116117118119120121122123128168 ... LastLast
Results 1,756 to 1,770 of 2524
  1. #1756
    Aug 2014
    clean inbox
  2. #1757
    Jul 2018
    I can make software on EasyDiag For Android, EasyDiag For IOS, EasyDiag 2.0, IDIAG, DIAGUNIII, ICarScan, GOLO, DBScar,
    ED 3.0,
    Please PM me.
    no need for flash.
  3. The Following 2 Users Say Thank You to Maclaren For This Useful Post:
    gigadiag23 (24th November, 2018), sarikayao (15th February, 2019)
  4. #1758
    Aug 2014
    ED 3.0, no need for flash.fake, it will not work well
  5. The Following User Says Thank You to enteran For This Useful Post:
  6. #1759
    Jul 2018
    Quote Originally Posted by enteran View Post
    not fake, we have a better solution.
  7. #1760
    Aug 2018
    gotta erase messages you inbox is full
  8. #1761
    Aug 2018
    Default easydiag 3 etc
    [QUOTE = enteran; 3350038] Zrobię oprogramowanie online dla tych skanerów: EasyDiag dla Androida, EasyDiag dla IOS, EasyDiag 2.0, IDIAG, DIAGUNIII, ICarScan, GOLO, DBScar, V, V +, V + (2016), V ( 2016), Pro, PRO (2016), PRO3, PRO3S, PRO4, ProS, 5C, HD /
    Napisz do mnie w prywatnych wiadomościach.
    Zrobię oprogramowanie online dla tych skanerów. [/ZACYTOWAĆ]
    Hello. What is the cost of obtaining flashing instructions and software eg pro3s or pro4
  9. #1762
    Aug 2014
    Please PM me
  10. #1763
    Aug 2014
    Recovery login and password from Launch account
    I need a photo adapter with a clearly visible serial number.
    pm
  11. The Following User Says Thank You to enteran For This Useful Post:
    bangreno (23rd August, 2020)
  12. #1764
    Aug 2018
    so how can i use the x431 launch software on a device that has a balance to be paid (matco maxme). can i use my dongle on the launch x431 pro software? could use the help of a veteran to walk me thru a few things... verifcation code is where i run into problems. somebody help
  13. #1765
    Aug 2014
    you can, but the software is not original.
  14. #1766
    badziewo's Avatar
    Feb 2016
    Universe
    @Enteran erase some messages from your inbox please.
  15. #1767
    Aug 2014
    erase inbox
  16. #1768
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    possible to update little bit cheaper x431 v ? android
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
  17. #1769
    Aug 2010
    Herts, UK
  18. #1770
    Aug 2014
    DANGER! NEW PROTECTION EASYDIAG 3.0
    https://yadi.sk/d/pGQTk2bKrrJz1A
    Inside the board are glued to the case. When opened, the adhesive removes the parts from the boards. It is necessary to enlighten the body with a bright light. See where the glue is. Heat the body, it will help. You can cut the area with glue. Black resin on the contacts for programming is removed when heated.
  19. The Following 5 Users Say Thank You to enteran For This Useful Post:
    abdonete (4th November, 2018), Col19 (24th January, 2020), gege974 (20th October, 2018), Nicolas9 (11th November, 2018), saidiag (21st October, 2018)
