i dont think it is a clone as i paid a fortune for the whole x431 kit a few years ago from a dealer. could it be a problem with my cf card causing it to not update as i have noticed since i put the cracked files on to the card and removed it from my computer my computer will no longer recognise it. the x431 seems to recognise it and download programmes to itself just the comp wont. also i had 200 mb of data on my card before i put the cracked data on it which only has 150mb of data, could there be some file missing that i need from my old files?
So the first thing i'd do would be get another CF card. Upload the cracked software onto it and try again. To be perfectly honest with you, my money would be on there being a problem with the canbus 2 connector itself, but its a lot cheaper to buy a new cf card. If you had 200 mb of info on the card before, its probably because you had a few different versions of software for each manufacturer on the card and the cracked software just has one for each. I have had problems with can bus 2 connectors myself in the past and im sure they were genuine too. You'll probably get a new canbus 2 connector for 50 pounds on ebay, they are not very expensive. You might want to get a super 16 instead. Saw one guy selling for 130 pounds sterling on ebay.co.uk .
jandial
100% your CANBUSII is defectve, reason???? CanbusII work great also with cracked software, so try to check with another Canbus from your friends.
Please can you tell us which version of cracked upfdates you have ( if it is newes, October, November or December) please pack it in RAR format your CF card, it will be oroun 50MB and upload them and give us a link.
hi, how crack any update for any scanner x431 ,
- this solution need s/n or not ?it will be around 50MB and upload them and give us a link.
hi how crack the update of sinodownload, how use for other x431 ????
Ok Jandial, no problem, but if somebody have newest cracked update please upload here
Connect x431to car. choose canbus2 upgrade symbol on menu. It gives two options. 1 read current version and 2 update. Firstly you read and if your canbus 2 connector has not been updated already,you should have v 2.0. If it does not even read what version you have, your canbus connector is broken. If it displays 2.0 then go to update. It asks you if you're sure you want to update, select yes, the screen tells you t wait and dont disconnect during the procedure. After about 20 seconds you should be updated to version 2.2 .
