Hello to everyone. I tryed your cracked version of X431 software and works perfect on my machine. Thank you all.
can any one post what the CF card brand is worked with launch x431.please... iwant o buy CF card for my x431.but now in my country is difficult to find CF card smaller than 2GB.thanks before,
somesoul
"can any one post what the CF card brand is worked with launch x431.please... iwant o buy CF card for my x431.but now in my country is difficult to find CF card smaller than 2GB.thanks before"
Any 512MB not bigger, you can slow down your machine. 256MB is the best, but anyway you can use also 512MB
somesoul,
Try SunDisk 1 GB, White Electronics Device 1 GB, SiliconDrive 1 GB.
As of my information it shouldn't exceed 50x speed.
Master Computer Engineer, A+, Network+, MCP 4/2k/2k3, MCSA/MCSE 2k/2k3, MCTS, MCITP Enterprise Administrator, Microsoft Certified Trainer/Systems Engineer, Brainbench, ICDL and starting Ph.D.
Hi friends:
my lunch x431 always gives error connection with ECU.
I replace OBD cable, still same problems.
does any one has experience on this issue.
thanks in advance .
@zcc:are you sure not exceed 50x speed??i read in other page someone have successed using 2GB CF card.
hi all , anyone use the canbus 2 connecor with this crack software , like mazda rx8 ?
cj
mastermind you are the man if you can share all car brand x431 update until nov 2009
@zcc are you try this crack software??how big CF card you use??i have successed using 128MB with some car brand i must delete to fit with CF card.
I repeat again use maximum 512MB of quality CF card, not bigger, because you can slow down you TOOL, I have prove with 1GB Silver 80x (kingstone) and it slow down my Tool for 60-70% (with over 60 software inside, 270MB), so make new CF with new update (cracked or original, have proved also with cracked), and work with new CF card ( best solution 256, but work good also with 512, maby for 10% slow down but acceptable) so dont use 1GB or 2GB anyway if you want good work of your Launch. If anyway need old software keep it in another CF card, change it carefully and use it!
