I did not read and understand clearly before that the cracked versions of the software posted in this thread only works for the older X431. It works for the older X431 that has external Super 16 adapter. The new X431 master and GX3 have the Super 16 and CAN adapter built into the main box. You only need a single 16pin adapter for OBDII and CAN. And when you run a vehicle diagnostic on the older X431 models it goes through 3 steps:
Resetting Smart box
Checking Smart box
Downloading Progra
On the newer X431's it does not have this "downloading program" step, it just checks and resets the smartbox then starts the main diagnostic menu for the vehicle. Hence it starts up a little faster.
I installed the 2010 version of the cracked software on my GX3. Then I did a few tests. It successfully checks and resets the smartbox but always gets a "failure" on the "downloading program" step. This is because my GX3 has the Super16 and CAN built in and is designed differently than the older X431's. It does not need to go thru that step. But the cracked version of the software is intended for the older machines that needs to do the "download program" step.
I gave it a go because I saw a post where one DK member says it worked on their GX3. It must have been the earlier GX3 models where the CAN and Super16 were not yet integrated inside the main unit/box.
Bottomline, it does not work for the new X431 Master and GX3 with built in Super16 and CAN adapter.
