hi all,i got the chip only to use on Diagun 2 to make it be open serial,i haven't tried that yet,i will share the info after i do that.....
racin-snake (4th March, 2014)
That's assuming they are correct chips etc
This is China nearly nothing is as it seems
CHIPS ARE 100% COMPATIBLE ! as said by GAZVTS good solution
Today is the Tomorrow you worried about yesterday ......Was it worth it ?
gazvts (4th March, 2014)
Here is my wallpaper
I've got the same openserial smartbox works great
Not that I need mine anymore tho
liber what help do you need with it ?
these are direct replacement for old mcu pre-programmed ( & protected ) working on 2008 pcb & 2012 pcb
Hi all
Search new update for this serial SN 980640763600 (X431 GX3)
Do you know how It work with diagun? Sn: 980540728600.
Cost? And do I get chip to replace or i have to send it to china?
Thx
Sent from my Nokia Lumia 920 using Tapatalk
please press the little red THANKS tab
if I helped u
hi rafekj,have a look for this sn,versions quite newer,but not free,see if you can bargain with him.good luck!
