will the update in the first post work for the launchx431 master?
ok i would like to know where the serial number is stored in the the actual updates anyone willing to share the info i am willing to have a play and compare software ect i can upload some of the lastest updates but they are ones already downloaded with the serial number in them
cheers
There will be no point in comparing your updates against the original cracked software from the first post in this thread as the software has since been changed by Launch. There is however a post for updated Toyota software on one of the posts on this thread, which has the new software security.
hi, how to change the serial number or adjust the update to x431 because it always displays this error,,, disacording between the software serial no serial NO.and Smartbox
Hi all, i have a problem, i was about to update my machine however after copying the original CF card to desktop, i inserted it back into my launch x431 (wiyhout using the cracked software) connected to my car, and now it loads up the software ie bmw, merc.. then when loaded i press OK and it says ' disagreement in software serial number and smartbox serial number- download or upgrade again' all i did was try to back up original???
any help as i am lost without my x431.. help please
Are you using the cracked software from this website ?
Its a simple procedure.
1. Download the cracked software from rapidshare
2. Unzip the file you have just downloaded
3. You will see two folders, One called Data and the other called GAG.
4. Put your cf card into your card reasder and into computer. Remove current contents on cf card.
5. Copy and paste or drag both data and gag files onto/into your EMPTY CF card
6. Put cf back into your x431 and bobs ur aunt, fanny's ur uncle :-)
Hi Cheers for the quick reply. No i just put my cf into the card reader, backed it up, then when i try and use x431- it kept coming up with the serial numbers not matching message (just from backing it up), i got worried and posted the message for help, then got impatient and loaded sunnyone files to it and it worked!!
Thanks anyway
hi, how to get an update despite the difference of the serial number? how
has anyone got any idea why my can bus ii connector isnt working after installing sunnyones update?
jandial
Seems that your CANBUSII was not genuine and when you do update you probably damage your CANBUS. I have damaged one CANBUS too ( chinese clown). Do not update CANBUSII clone, use only w/o update. If you do not update with CANBUS version 2.2 it is possible to be damaged on vehicle if you connect first a CANBUSII connector to vehicle 16 pin before you connecting on Launch connector , in this case if you connect to Launch after vehicle connect, it is chance to make accidentaly short circuit inside when try to switch 15 pin female with 15 pin male connector, you know you can not switch sometime at first time, so when you failed to switch you can touch any wrong pin so also can damage your CANBUS. Hope it is clear. Also hapened too many cases I know.
Hi I have the cracked software and have updated a few canbus2 adaptors NO PROBS , today i also updated my Super 16 for me and a friend.. Works GREAT- dont need my CAN BUS 2 or OBD2 adaptor anymore
Also Launch is Chinese company (I have visted the factory)
You can post the cr- acked files here.
Will be very appreciated.
Thank you
i tried to update teh connector but it fails to recognise it when trying to update it. it powers the x431 and all but i cant read or update the firmware.
