Hi what is the handy way of programming a blank non remote key for ths Audi A6 2006 3.2fsi with AVDI?
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
Hello.
1) Dear, first connect by jumper wire the pin 1 + the 16 of obd2 to have communication with engine ecu, and after with avdi go to Special function of (EZS-kESSY q7/a6) and click (Auto detect - from engine ecu) when it show you 6 cs + pin, so there put your transponder 8E OR remote and in (tag key tool) click Make Dealer key,and follow the procedure of avdi screen.
2) if American system the car so must be your remote part number (4F0 837 220 A) if EUROPE (4F0 837 220 M ) if any missing or misunderstand me please let me know.
amigokola (8th July, 2016), gttuning (29th June, 2016), Jobeso66 (11th December, 2017), lock66 (23rd October, 2018), Serg1o (9th October, 2019), solarsun (12th July, 2020), songokus (24th February, 2017), ThiagoArgentino (29th June, 2016), totalkey (7th July, 2016), Toutancamon (3rd August, 2019), vsanyi (9th December, 2017), yugo45 (7th July, 2016)
Hi again was looking for this 8E transponder chip where, i can get it them from. 3Dgroup r listed for Ssangyoung will them work or has to be 8E for VAG?
Hi, I have same situation , I followed your steps to read KESSY
2006 Audi A6
How long does it take to pull component security from ECU?
It goes to 10 mins then says it needs more time , it goes to another 10 mins cycle.
Am I doing something wrong ?
Hello.
yes some times need more then 30 minute leave ignition on to let you get immo infos.
topclef (5th December, 2017)
can't buy remote fobs anywhere ??
I am a FUD
Jobeso66 (5th December, 2017)
AVDI will not read some older Simos Benzin ECUs. This mainly goes for older 2005 models here in US. You might be able to read info from EZS. Most require working key, but some older EZS versions do not. Try reading EZS with "have working key" option.
doctore (5th December, 2017), obdsystems (6th December, 2017)
Out of stock.
Finally I had a chance to get back to this vehicle, I have a lost key situation
I have a key cut with a new 8E chip
After 30 mins powering ecu direct I hooked up fvdi , selected ECU ICON , on next screen I clicked on read conf data ( by default on auto detect)
It has this ecu
Ecu Siemens VDO
5WP45186 06 RBG. SME 0254/0393
simos 6.22
4F1 907 559 A. H15
SW 4F1 910 559 A. 0050
