Page 2 of 10 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 150
  1. #16
    Quote Originally Posted by autochei View Post
    it s safe to read pin with this tool?
    need a charger batery when read pin code
    i sow a video it s need ignition on-off and after 5-10 minutes it s code pin
    yes its safe, its a copy of PSAI2EMU or TDB007 - not sure if it can do all keys lost like TDB007.
  2. The Following User Says Thank You to paul_12345 For This Useful Post:
    autochei (12th September, 2016)
  3. #17
    P&D's Avatar
    Quote Originally Posted by davidobd2 View Post
    Hello everyone. I was looking in internet and I found this tool. Somebody knows something about this? It says read pin code for Peugeot/Citroen via OBDII. Here is the link:
    http://www.obd365.com/wholesale/obdstar-f108.html
    Best Regards.
    Same item ?30 cheaper .......http://www.obdstarstore.com/wholesal...ming-tool.html
  4. #18
    Fallen's Avatar
    Tried direct connection to ECU on that same early berlingo, did not read pin, would not connect by obd to program key.
    If anybody is buying this for non-can pin reading, forget it.
  5. The Following User Says Thank You to Fallen For This Useful Post:
    tomasete (5th December, 2017)
  6. #19
    autochei's Avatar
    Mar 2013
    romania
    vehicle suport it s only after 2008?
  7. #20
    Apr 2016
    uk
    I heard someone who said that read pin on a Peugeot 2007..
    Inviato dal mio HTC One utilizzando Tapatalk
  8. #21
    west mids, uk
    it is a shite tool.
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  9. The Following User Says Thank You to ninja123 For This Useful Post:
    Fallen (12th September, 2016)
  10. #22
    daniersms's Avatar
    South Africa
    I use mine just to get the pin and it saves some time
    Love this forum
  11. #23
    Sep 2016
    If all key lost, you need to get pin code from car service center and program auto key with F108.
    Eeprom adapter can read partial pin code for Peugeot/citreon/DS
  12. The Following User Says Thank You to Susan For This Useful Post:
    Galee (16th September, 2016)
  13. #24
    Sep 2016
    Usually it supports vehicles (with CAN line) after 2008.
    But it depends on the acutual case if the immobiliser systmes are the same.
  14. The Following User Says Thank You to Susan For This Useful Post:
    autochei (13th September, 2016)
  15. #25
    lion0304's Avatar
    Oct 2014
    207 -07: about 7mn
    Jumpy - 08/09: about 6mn.
    All for additional key. Use pin and program with X100+.
    For me, it worth the money. It save me many time to have money in poket.
  16. #26
    Jul 2016
    Hi, do not worry, F108 PSA tool is just read pin code, not modified any things, it is safe.
    No need extra charger battery, just connect this with your OBD
    About the time of reading pin code, it depends on car type, such as its immo chip, algorithm...some take around 2 minutes, some take 5-10 minutes..
  17. The Following 2 Users Say Thank You to Jady from OBDSTAR For This Useful Post:
    autochei (20th September, 2016), p1et (19th September, 2016)
  18. #27
    Sep 2016
    Shenzhen
    hi, it is safe to operate it. It doesn't need charge battery. As for the time of turning off ignition, it depends on the prompt on the device. Thank you.
  19. The Following User Says Thank You to Ice Shi For This Useful Post:
  20. #28
    Aug 2016
    I have extracted pin from over 20 cars, all fine. Not necessary to connect charger to car as it doesn't put Bsi in service mode like psa bsi tool, or avdi where windscreen wipers would activate etc. On average 5 to 8 minutes, although a 508 and a 2008 I did it found code almost instantaneously.
    It is only for cars on canbus. It specifies it on their site also.
    Sent from my HTC One M9 using Tapatalk
  21. The Following 3 Users Say Thank You to Sergio101 For This Useful Post:
    autochei (21st September, 2016), p1et (21st September, 2016), rob h (24th October, 2016)
  22. #29
    rola1971's Avatar
    Jun 2014
    Dublin
    this peugeot-citroen function for free this moment in VVDI2
  23. #30
    securipro38's Avatar
    EU
    Now F108+ seems to be f108 upgrade but but with k line for older cars.
    Just added a few components on main card
    I think strategic marketing
    Obdstar tools are good but too many new products
    I remember the day I buy X100 but one month later new product X100 PRO no more upgrade for my x100
    F108 works good for pin extraction on CAN cars but key programming function does not work at all
    I sent several logs from TF card but no news about them
  24. The Following 3 Users Say Thank You to securipro38 For This Useful Post:
    autochei (24th October, 2016), danielif (27th August, 2018), rob h (24th October, 2016)
