Hello everyone. I was looking in internet and I found this tool. Somebody knows something about this? It says read pin code for Peugeot/Citroen via OBDII. Here is the link:
http://www.obd365.com/wholesale/obdstar-f108.html
Best Regards.
mexanico1971 (11th September, 2016)
Has anyone managed all keys lost with this tool
Fallen (23rd August, 2016), runtronics974 (28th September, 2016)
Has anybody read a pin by direct connection to ECU?
no, not even the guy from avdanced keys who I have watched testing this crap for months!!
DK- The Bogs Dollocks!!!
NEVER SAY IT CANT BE DONE!!
The thanks button works wonders!!
DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
was it the ad one or this one mate?
should be easy enough to rig a couple of cables for can and kline
I just read made a try this afternoon on 207 2009. Need igntion On - OFF 10 times in 7mn. Pin read succesful.
alle bmw (1st February, 2019), runtronics974 (28th September, 2016), toshiby (25th August, 2016)
had you used the function key programmer? i see demonstrations on you tube only for read code pin
I not program key yet, just received and have a car for testing pincode reading.
Usual with pin, i use Lexia more comfortable for coding.
Hi guys
I have one of these and I ave successfully made 7 remote keys using this. I?ll ellaborate, because its not peftect, but it has already paid itself off so im very happy nonetheless
the first car I did was a 2012 308. (I generated a remote using kd900) It read pin code within 6-7 minutes. all fine. But then when i attempted to program, first trying by brand and model, then by immo type, no joy, so i used an skp900 to code it, and good as gold.
with a 2010 C4 picasso, same thing. would read pin but no code.
So i have just used this little device for reading pin codes and so far 100% success, but havent bothered trying to code with it any more.
Personally I would recommend it to anyone thinking of buying one as its cost is low and 1-2 keys pays for it already, but my recomendation, think of it a a pin reader only and program using whatever means you would normally use.
p1et (25th August, 2016)
This read pin for lost keys or spare keys
i think only spare. next car i do i will try and read pin with a key with no transponder and see what happens.
dimet (11th September, 2016), mikajna (30th August, 2016), p1et (25th August, 2016), TERMINATOR1000 (31st August, 2017)
it s safe to read pin with this tool?
need a charger batery when read pin code
i sow a video it s need ignition on-off and after 5-10 minutes it s code pin
