Cross EPG Error
Results 1 to 4 of 4
Thread: Cross EPG Error
    Default Cross EPG Error
    Hi all,
    would appreciate help, when trying to download the crossepg it keeps coming up with this error:
    Timeout for Tuner lock?
    Martin
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Sounds like tuner connection bad how many tuners and are connections good? check cables and reseat properly have a look at sat finder in settings check signal on each tuner.
  3. The Following User Says Thank You to DOUGALMCD For This Useful Post:
    martin035 (2nd July, 2016)
    It was set up for twin tuner but ive moved to another room as I now have the Vu duo 2 upgraded
    all fixed now the room I moved to is a single feed so just had to disable tuner 2 and bingo it worked
    thanks for your help
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Glad your sorted.......
