lidons (10th June, 2017)
My card with TMCF: 00 8A 48 54 is detected as pcf7961
and card with pcf7941 is TMCF 00 80 04 83
SYNC is little different in some cards and I think is not important.
Have you tested it on Laguna III? or Koleos?
And question - have you tried to UNLOCK this card with know PIN/crypto data, after programming to the car?
Hello
all Chinese cards successfully programmed on MEGANE 3 , all with pcf7961 firmware detected ...
.... tried to UNLOCK : never tested yet
Hi there
I coded in a card to a 2015 Renault kaleos
With avdi card worked but remote not , it read as a 7952 , is this the wrong card for car or could it be procedure error, we left key in slot as it was a virgin key probably from china , avdi instruction not so clear, or must this have a dealer card
Need to sort this as customer wants full working card
Thanks for any info
Card with pcf7961 tested and yes can be unlocked with known ISK. this card shell is sized like original - can fit into reader.
Card with pcf7941 too thick! cannot fit into reader (tested on ScenicIII) Beware, do not buy.
Please someone test pcf7961 into lagunaIII if remote work. and report. we need more info.
I also bought some time ago "original" card to SIII with silver logo, it came with pcf7952. I added to car - remote didn't work! but before programming I read this card data and also unlocked it with known ISK, so dont be afraid testing it. you can always unlock.
With FVDI/VVDI2 it reads all full data from new card, but do not use EFFI ! it cant read page 0,1,2,3 data! Look into picture
You need to ask seller to read transponder and send you pic before buying. Because many sellers they dont know what they are selling! But they have acces to read a key and make a picture for sure.
Where to buy good cards for all renos?
where remote also work. For goid prices. As now i found only original 100eur 1 pcs.
Hello
25 € in china , PCF7961 card ! ( 100% operational remote control )
https://fr.aliexpress.com/item/Excel...608.0.0.mR5FqB
Whe they write 7941?
im looking at oem card specs. this is correct pcfs?
clio 4/capture pcf 7953
Renault Keyless Go/Handsfree card for Megane III, Laguna III, Scenic III, Fluence, Zoe, Latitude pcf7941 ?
dont see any pcf7961
Did you know - every time after you press button, data is changing in pcf7952 cards? That means page0 & page3 its not important, only "config" data is important... Look at the pic
raptureready (20th June, 2017)
As about card from that link. In feedbacks i see that its not like advertised.
You realy tested .start and remote work? Car fit in reader?
This reading is from original card, all original number under battery cover, "continental" and numbers. I doubt its china card.
