Results 1 to 14 of 14
    sdnatlst's Avatar
    Aug 2011
    England
    Default saab 93 spare key, which tool
    hi all got saab 93 spare key to do, 2006 model.
    i never done one before, what of my tools will do it? Lonsdor, Autel 508, OBDstar X300DP ? anybody used these on this car before please
    thanks!!
    Tools owned -
    AD100 PRO, Lonsdor, FVDI 18, FVDI 20, VVDI PROG, VVDI2, VVDI MB
    CGDI BMW, SuperVag, Renault ECU tool, OBDstar X300 DP Plus, AUTEL im508
    VVDI Mini Keytool, KeyDIY KDX2, SBB, ACDP CAS/KVM
    Opcom, VCDS pro, Diagbox, Multiecuscan, Forscan, JLR SDD
    p1et's Avatar
    Oct 2013
    I think none of mentioned above can do this. For sure MVP pro can.
  3. The Following User Says Thank You to p1et For This Useful Post:
    sdnatlst (23rd January, 2020)
    sdnatlst's Avatar
    Aug 2011
    England
    Thanks.
    Autel shows it listed but never tried it.
    Tools owned -
    igorr's Avatar
    Aug 2010
    Lok at the vvdi2 key from dump eeprom meny, I done 2-3 cars vith tango, they have similar meny
  6. The Following User Says Thank You to igorr For This Useful Post:
  7. #5
    Top Poster dooshan's Avatar
    Mar 2012
    Belgrade
    By dump, many tools. By obd, done by tech2
    Sent from my LYA-L29 using Tapatalk
  8. The Following User Says Thank You to dooshan For This Useful Post:
  9. #6
    sdnatlst's Avatar
    Aug 2011
    England
    Thanks guys
    Also how we get the immo pin code
    Dealer only ?
    Someone told me it's written on ECU label but not too sure if really would be that easy...
    Tools owned -
  10. #7
    Mar 2012
    Belgrade
    Quote Originally Posted by sdnatlst View Post
    Thanks guys
    Dealer only ?
    93c66 in CIM
  11. #8
    p1et's Avatar
    Oct 2013
    Thanks guys
    Dealer only ?
    I can give you PIN from VIN aswell as some other members in this thread:
    https://www.digital-kaos.co.uk/forum...05#post3773505
  12. The Following 3 Users Say Thank You to p1et For This Useful Post:
    ASCM (4th May, 2020), sdnatlst (23rd January, 2020), super jumbe (23rd January, 2020)
  13. #9
    sdnatlst's Avatar
    Aug 2011
    England
    Awesome p1ete
    I have posted my VIN!
    Tools owned -
  14. #10
    HeXeN's Avatar
    Mar 2015
    What tools can add key with known pin code?
  15. #11
    Mar 2012
    Belgrade
    Quote Originally Posted by HeXeN View Post
    I use MVP with Pin. But mainly I dump them with image files.
    With tech2 when they lost sync.
  16. #12
    Mar 2012
    Belgrade
    Thanks guys
    Dealer only ?
    And.... pin by vin on TDB web site . Totally forgot about that ...
  17. #13
    sdnatlst's Avatar
    Aug 2011
    England
    P1ete it says pin code check failure on autel. After it asks ignition on and off
    Tools owned -
  18. #14
    p1et's Avatar
    Oct 2013
    Try with MVP pro. I just double checked and 9CUX is correct, unless someone changed CIM modules.
  19. The Following User Says Thank You to p1et For This Useful Post:
    sdnatlst (25th January, 2020)
