Results 1 to 7 of 7
    audiotek's Avatar
    May 2011
    Default 2014 Dodge Journey BCM mcu MPC5515 read advice
    Hi friends, I need your help to read this mcu: MPC5515, from 2014 Dodge Journey BCM.
    This is the connection diagram from ELDB:
    http://www.eldb.eu/download.php?file...ee_wk_2014.pdf
    What other progammers can read/write this mcu? versions 5.5.1 and 5.5.5 for xprog clone can't read this mcu, no one have "Freescale MPC55xx" section in "MCU/MPU" menu. In china version 5.60 this section is present but only MPC5516 is included.
    Thanks for your advice...
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Willem PCB50, Masterprog, NecProg, Orion, Ponyprog, Carprog, Renesas H8SX, MT60/80, SPC560 programmers,Obdstar X300DP, EZ500, CHIPSOFT MID,SKP1000,Cantool, SuperVag 3.0, Vag Commander, Vagcom Original, Launch x431 Pad, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Mastertech VCI, EASE j2534, Ford & Mazda VCX, TS401, Cardaq-m, DIS 5.7, VAS5054 Plus, Tachopro 2.0 & 2008.01, Vag K+Can, JLR v141.....
    audiotek's Avatar
    May 2011
    Someone has used xprog to read this device? Please share your experience. Thanks in advance...
    audiotek's Avatar
    May 2011
    Default Job done!
    I decided to make an investment and order an original Xprog box programmer with full authorizations from ELDB and finally I can finish the job, reading, editing and writing perfect without any issues, xprog can read/write the flash and shadow sections of MPC1515.
    Here are a few pictures: MPC1515 FLASH READ.jpgMPC1515 FLASH VERIFY.jpgMPC1515 FLASH.jpgMPC1515 SHADOW READ.jpgMPC1515 SHADOW VERIFY.jpg
    Canada
    how much was it with full authorizations
    If i helped you please press thanx
    audiotek's Avatar
    May 2011
    It's about us$2,000 dlls, but it worth, is very fast and reliable.
    bearheroes's Avatar
    Dec 2011
    Quote Originally Posted by audiotek View Post
    Of course it worths...you get what you pay!
    It is rule!
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
    Aug 2015
    hi audiotek
    i have BCM cherokee 2014 and i have XPROGM original. it is sam diagram you sand. I'm tray to reed the error chow (connection out ) can you halp
    haw you read the BCM?
