toshiby (1st September, 2016)
very good but newbie.let wait and see in future it will be powerful.i have my and work great and i'm very happy with it.no lie
I tried with HDS to program key and used terminator as a passthrough. Selected FVDI2 for device. It would connect ok for diagnostics, scan car but just loop when adding a key without doing anything.
So even passthrough doesn't work. Engineers are asleep
2016-8-24 V2016/10/14 Released:
Function 1. A4/A5/Q5 2007+ Generation 5 Immobilizer Functions:(
1.Read BCM2 Immobilizer Data By OBDII;
2.Generate dealers keys and key learning;
3.Open/close Immobilizer Horn;
4.Recover Emergency data(Data recovery and wake up in the process of reading immobilizer data failure cases);
5.Check the new PCF7945AC (HitagExt VAG);
6.Load decode file (Can generate dealer key and learning key);
7.Load PFLASH and DFLASH file (Can generate dealer key and learning key);
Note 1:
1. Item 6 and 7 are new functions;
2. Item 7 can do all lost key;
Function 2. A6/A7/A8/VW Touareg Generation 5 Immobilizer Functions:(
Note 2:
No.1 List of models:
1. Audi A4;
2. Audi A5;
3. Audi Q5 2007+;
4. Audi A6;
5. Audi A7;
6. Audi A8;
7. VW Touarge;
Function 3. PIN Calculator Functions:(
1.Nissan 20-digit and 5-digit PIN Calculator;
2.JLR SDD Coded Access Password Calculator;
3.Ford and Mazda Incode Calculator(Include 6-digit,12-digit or 16-digit Outcode);
4.Honda Password Calculator(Include First Password, Second Password, HIM Unlock Password and 4-digit PCM Password);
Function 4. Reset of Toyota/Lexus/Subaru Smart Keys Function:(
1.Reset of Toyota/Lexus/Subaru Smart Keys 40,80,128 bit;
FLY OBD Terminator Support car List
1. ALL Honda; 2. ALL Ford; 3. ALL Mazda; 4. ALL LandRover; 5. ALL Jaguar ; 6. ALL Toyota and Lexus ; 7. A4/A5/Q5 2007+ Generation 5 Immobilizer;(
);8. A6/A7/A8/VW Touareg Generation 5 Immobilizer;(
);9. PIN Calculator Functions:(
);10. Reset of Toyota/Lexus/Subaru Smart Keys(
);11. VAG Generation 4 Immobilizer,NEC Dashboard 95320;(
1.Automatically recognize VAG Generation 4 NEC 95320 Dashboard;
2.Add VAG Generation 4 NEC 95320 Dashboard key directly;
3.Read VAG Generation 4 NEC 95320 Dashboard Immobilizer data;
4.Modify VAG Generation 4 NEC 95320 Dashboard Immobilizer data;
5.Read and save VAG Generation 4 NEC 95320 Dashboard configuration data;
);12. VAG Generation 4 Immobilizer, NEC Dashboard 24C32; 13. JLR SDD Coded Access Password for Locked Functions;
1.Jaguar:
CCF EDITOR
ODO APP (X150)
ODO APP (X250)
ODO APP (X351)
SOFTWARE DOWNLOAD
VID BLOCK EDITOR
VIN BYPASS
RECOVER KEYS (X351)
; 2.Land Rover:
CCF EDITOR
ODO APP (L316))
ERASE KEYS (L322)
ODO APP (L322)
RECOVER KEYS (L322)
OPTION 8
SOFTWARE DOWNLOAD
VEHICLE UPDATE (Only Taiwan models)
Hi, Totoo,
online update ONLY updates the firmware.
How to download new terminator software if it's needed for all above functions?
I have 001.00077 version and all above don't work
Says NOT CONNECTED to the car
why publish things not working
publish because of poor product quality .of inadequate technical support
bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
2016-11-15 V2016/11/15 Released(First in world):
1.Edit ID of PCF7945AC (Hitag VAG)/ Edit Audi Generation 5 Immobilize deputy factory Key ID.
tried on 2 Honda's with push button, first tried via supplied HDS software and passthrough, it detects car, but can NOT enter fob programming, when start it it loops back to the key menu.
Then I tried using Terminator software and can NOT make a connection to car.
Ford IDS could not connect to 2016 van,
Still needs work.
where in opel insignia?
