Results 1 to 2 of 2
    Jul 2016
    Downloads
    4
    Uploads
    Default Openbox z5 HD mini
    Openbox z5 HD mini
    unit dead, while upgrading online
    only 1 red light burning on power on
    no display
    now using :
    Uart Getmecom Sunplyus Series
    KDP8006_SKN_OPENBOX_Z5_B14016_20141014.bin
    Port setting on application Port Com 1, Bits per second: 115200, Parity:None, Data Bits : 8, Stop Bit 1
    Port setting on PC: Port Com 1, Bits per second: 115200, Parity:None, Data Bits : 8, Stop Bit 1, flow control: none
    When application run:
    Connection Success....
    Please Open STB....
    (STB power on, it was off before)
    handshaking with slave..
    Outcome:
    Nothing Happens for a long time
    Please advise if the above setting is correct or not
  2. The Following User Says Thank You to haneef For This Useful Post:
    losdosymas (12th August, 2017)
  3. #2
    Aug 2010
    Downloads
    Uploads
    Sorry have the program for openbox z5 mini
