Hi FORD FUSION 1.6 tdci - BOSCH 0281 011 612. I have DTC P1259 and no start car.
Can you help me please?
Thanks in advance
Attachment 387404Attachment 387405
please password file
Thank you Lion0304 , everything works, greet cudzy
Hi, can I have some help too ? I read the .bin file from the ECU 95160 eprom and MC9S12H256 dump from dash. Pls help !!!
THANX
95160-on.zip
semga (22nd June, 2017)
Ford fusion ecu edc16 eep 95160
Dash visteon 24c08
Need synchron dash and ecu
Problem appear by low battery
gege974 (16th October, 2018)
THe problem with ford fusion is on my collegue car ! I was yesterday reprogrammed 2 keys with vcm , and needed to reprog pcm , but not option . After reprog 2 keys immo light do not turn off on dash and not blinking ! We check all fuses are ok !
SO i think must be any sync problem ecu + dash .
yes , i upload that file ! Can any tell me is already synchronised ecu with dash ?
Can you help me bro ? Can you make Sync ? On that car vcm ids not has aviliable module programming , so i can not flash the pcm
kumbari (24th June, 2017)
