Use iron heat sold both pin 6 & 8 wire from xprog to dash in pin 8 is ok.
Hi guys,
i have a problem with my yamaha r6 rj09 (2004) dash.
I try to read the 93C56 with X-prog, but x-prog says bad connection at pin 6. (pin 6 is not connected)
i have a wiring diagramm from another forum but this is for enigma.
Problem now;
in X-PROG there are the pin numbers B0,B1,B2,B3,B4,B5,B6,B7.
In the ENIGMA diagram (in attachment) there a pin numbers 1,2,3,4,5,8.
I connect B0 with 1, B1 with 2, B3 with 4, B4 with 5 and B7 with 8.
I try to read with x-prog and he says "error bad connection at pin 6."
Is my wiring wrong?
on these dash the eeprom is under a lcd display, so i can not desolder the eeprom.
big thanks!YAMAHA R6 FROM 2002 TO 2005.pdf
When i understand your post right i must connect B5 and B7 with pin 8 to dash?
now another error comes "bad contact at pins 1,2,3,4"
Here is the connection for u ,Yamaha R6.jpg Yamaha R6YAMAHA YZF R6 POWER CONNECTION.jpg With power connection
Nothing will remain in this World , Everything will come to END!
THINK POSITIVE NOTHING IS IMPOSSIBLE
Please do not spam by PM asking for help. Use forum, that is why we are here.
same problem.
When i select "FAIRCHILD" -> "FM93C56" there comes the error "bad connection at pins 1,2,3,4".
here is dump;
r6_win7.rar
odometer are 42-44.000km.
Odometer are 43954Km!!
Yes its correct. But when i write new file with new odometer, error comes.
Try Backup with ATMEL , ST and CATALYST (x16) and try write it using those Brand ..
in the past i bought a VVDI Prog.
I will try to test it now with VVDI.
anyone has the pin numbers for VVDI?
[QUOTE = bmw335coding; 2812369] Ahoj kluci,
mám problém s mým yamaha r6 rj09 (2004) pomlčka.
Pokusím se číst 93C56 s X-prog, ale x-prog říká špatné připojení na pin 6. (pin 6 není připojen)
Mám schéma zapojení z jiného fóra, ale to je pro enigma.
Problém nyní;
V X-PROG jsou čísla pinů B0, B1, B2, B3, B4, B5, B6, B7.
V schématu ENIGMA (v příloze) jsou čísla pinů 1,2,3,4,5,8.
Připojuji B0 s 1, B1 s 2, B3 se 4, B4 s 5 a B7 s 8.
Snažím se číst s x-prog a říká "chyba špatné spojení na pin 6."
Je můj kabeláž špatně?
Na tomto pomlčce je eeprom pod LCD displejem, takže nemohu odštěpit eeprom.
velký dík! YAMAHA R6 OD ROKU 2002 DO 2005.
Try this for Xprog.
Write to new eeprom
BMW FOREVER
upa usb no work without isp adapter xprog work read as fairchild (national) and write only chang data . no need desolder lcd .zckariya70 power up not work .
One picture the Dash r6
