Xbox complete guide to flashing, burning games..updated - Page 2
Page 2 of 15 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 212
  1. #16
    Sep 2008
    I want to install firmware 1.61 on my samsung drive, i have only ever flashed it 2 times, the last time being 2007 or early 2008 when my friend had prepared a floppy disc for me with files and a set of instructions. Basically from there all i had to do was connect the drive to my pcs mainboard via sata, and execute the floppy disc using a command name, that's it.
    I can't get hold of my friend anymore, therefore now need a noobs guide in upgrading the firmware, i say noobs guide as i require detailed steps right from the beginning of what programs/files i need, how to create that floppy etc.
    Any help will be appreciated, thanks.
  2. #17
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    Best method is using dos to flash the samsung. The tutorials on here explain everyhthing.
    Good luck.
    If you get stuck give me a shout and i'll talk you through it.
    Patience is a virtue.
  3. #18
    Nov 2008
    Default backing up xbox360 games
    hi everyone and merry xmas
    i use imagine burn and keep gettin a message sayin failed to set lo data zone capacity
    can anyone help cheers
  4. #19
    hey, just wondering if someone can give me some help. the more readin i'm doin the more i'm getting confused.
    basically i have a lite-on drive,
    model: DG-16D2s
    fw ver:74850C
    this drive has basically packed in, kept gettin the "unreadable disc, take out disc and clean" even tho it was a new disc, then tried games i already had and it was happenin with that, got the new game changed and it was still happenin, now the games dont even load.
    so anyways, my dads mate had an old xbox360 which the graphics packed up on and its got a hitachi drive
    model: GDR-3120L
    dont see a FW number
    so my question is, whats the best way (without soldering) to be able to use the hitachi drive in my xbox360?
    any help would be greatful
    cheers
  5. #20
    Jul 2008
    cmd
    If it was flashed use jungleflasher to extract the dummy.bin from it. Extract also extract the key.bin etc.
    Flash the hitachi with the ixtreme 1.51 hitachi firm and then flash over the key and spoof data. Done.
    There is tutorials on here on how to do this. Also get the latest version of JF. And read up on how to spoof hitachi's.
    If you dont do a hitachi properly then you can brick them.
    The easiest option would be to get a new liteon drive or benq (i prefer benq drives) and flash the data over.
    You cant brick these so you can play away with them until you get it right.
    Good luck.
  6. #21
    neither have been previously flashed as far as i know, when i opened both xbox's, they had the seal on them so the drive hadnt been opened before and the guy that gave me the hitachi drive, wouldnt bother messing bout with that kinda stuff
    cheers again
  7. #22
    Jul 2008
    cmd
    Its your only option. You have no choice. The key from drive is specific to motherboard
  8. #23
    kl, going to have a bash at this today, n see how it goes. really just taking the guides from here n ee wot happens
    cheers again
  9. #24
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Added MRA Hack Guides for both Switch and Probe V2 methods from team xecuter.
    Both these methods, done correctly will retrieve firmware off any liteon drive flashed with any Firmware
  10. #25
    Question flash liteon
    I have a question: Is there any possible way to flash the series 9 liteons without having to cut and solder with jungleflasher?
  11. #26
    cunny's Avatar
    Jan 2009
    The Shoutbox
    No, MRA hack only 1 avail
  12. #27
    hey im new here and have been getting issues backing up my games using agbx360.
    it shows ss,dmi,pfi being blank and stealthcheck fails..anybody seen this problem or know of a solution ..im ripping my hair out with this..backed up 10 of my games already and been reading alot of tutorials and watching videos so i can fix this without relut..thanks for any help
  13. #28
    Nov 2008
    Default OPEN TRAY when loading game
    done everything has said mate right down to using Verb discs but when i load the game i always get the Open Tray message??,any help would be grateful as i am slowly running out of the expensive Verb discs!!!
  14. #29
    Member shilo's Avatar
    Nov 2008
    leicester uk
    Quote Originally Posted by spurs2000 View Post
    The same thing has happened to me. i had the relevent f/w flashed to my hitachi drive. the xbox plays originals fine but refuses to play any verbs . i have been told that the lasers on the hitachis are weak in the older models, so instead of doing a pot tweak to the laser i have ordered a new one off ebay as i thought that this would be the best option, will this work?
    I AM A MIME MY BODY IS MY TOOL!
    NOW GO AWAY OR I WILL
    TAUNT YOU A 2ND TIME
  15. #30
    Oct 2010
    Default x box 360 flash
    i was told if you flash the drive yoyu get kicked out of x box live is this true
