I changed ecu ( BMSKP ) on this moto, but the engine does not start. I've got used ECU with a key. I'm changing the vin code with tool32 ( choose file MRBMSKP.prg), but it says error and does not change. Is it possible to change the VIN code with ISTA/P? Motorcycle is 2013 year, the ecu i installed is made in 2012. Some say that it won't turn on without changing the VIN code in the new ECU. Need any kind of help. Thanks in advance.
Tariel (24th July, 2016)
Hi Gepa. The moto came from an auction without an ecu. I have another ecu with key, but the engine does not start . Dashboard does not show any kind of an error. When I turn it on with another key, the dashboard says ! and EWS. When i try to turn it on with the new key and turn the throttle manually, the engine turns on. What should I do to make it start? When I install the same key and ECU on another moto, it does the same. When I take the ECU and the key from another moto, it does exactly the same, meaning it does not start.
This ECU and the key did the same thting on another moto. (this moto works) When the ecu and the keys of the other moto are connected to my moto, it does the exact same thing, meaning it turns the starter but does not start. I cant read flash. Can read the keys though.
hi, all ground wires ok?
https://www.youtube.com/watch?v=sX6lqgk1eW4
engine started after opening the throttle manually
When I try to change the VIN in tool32 it shows this error, what does it mean?
JOB_STATUS = ERROR_ECU_REQUEST_OUT_OF_RANGE AIF_NUMMER = 2 00 02 ..
AIF_DATEN = 64 Bytes
000 : 40 5A 4C 31 37 38 38 35 20 16 07 24 00 00 08 52 @ZL17885 ..$...R
010 : 41 19 00 00 08 52 41 14 00 00 08 52 88 47 01 11 A....RA. ...R€G..
Tariel,
What command do u run in tool32 to change vin?
c_fg_schreiben
second test - aif_schreiben. After "aif_schreiben" :
Vin kods ro chacer boloshi 1 iani miamate da scade aba
cesit checksum unda boloshi
c_fg_schreiben da c_fg_auftrag aris sachiro,
an WinKFP ti gadaprashivkeba
checksum is " A " ( read with NCS ). today write vin "c_fg_schreiben and c_fg_auftrag" ( job status "OKEY", c_fg_lessen show new VIN ) but rheingold show old ECU vin. After "aif_schreiben" :
010 : 41 19 00 00 08 52 41 14 00 00 08 52 88 47 01 11 A....RA. ...R?G..
and aif _ lessen show old ECU VIN. I think problem with "aif_schreiben"
its fine,
its just UIF (tool32 does not update it)
to update it you need to flash the module with WinKFP
VIN should be changed now
" Tool32 AIF writing VIN MSS54 BMW "
https://www.youtube.com/watch?v=NQkKzv5NvW4
My problem is : " ERROR_ECU_REQUEST_OUT_OF_RANGE "
