time out for tuner lock
Results 1 to 12 of 12
    Oct 2015
    Default time out for tuner lock
    little bit oh help
    autobouquetsmaker timeout for tuner lock open droid 4.1 sunray sr4 a8p
    DK Veteran lincsat's Avatar
    Jun 2008
    No signal, poor signal, wrong region selected, incorrect tuner config
    Oct 2015
    many thanks for you quick reply signal is good just put my zgemma star h2/t2.c with open vix all channels working net id 00004//frq 755 provider sky hd wales/virgin uk still no joy is there a better image out there to us for sunray sr4 a8p
    regards
    beano2
  4. The Following User Says Thank You to marko12 For This Useful Post:
    haribo (30th July, 2016)
    Jun 2008
    Is the Sunray a single Cable tuner or the Triple tuner. If the Triple tuner, then you need to set it up differently. BTW, the Default or EPG frequency is 643MHz, SR=6887, QAM=64 for Pure NTL areas. Try a manual scan on that frequency and see if you have a signal
    Oct 2015
    hi it a sunray sr4 a8p Triple tuner you can see the 3 tuners ive got 28.2 its cable side i just change the setting to the one in your post but sill nothing found
    Jun 2008
    The Triple tuners need setting differently, you can't use ABM as you have to change the frequency. You will need to do a Google search to find the procedure, I just found it in seconds. This is part of it
    The main thing you have to remember here is the frequencies you enter needs to have a 01 in front of it. So if a frequency for your area is 643.000 you loose the 000 from the end and put a 01 in front of the 643 so you end up with 01634 in the frequency entry. For the symbol rate you need in most cases a zero in front so 6667 will be entered as 06667.
    You may also be able to edit the Lamedb or satellites.xml, I last had one about 5 Years ago, it was a pain to setup but did work.
    Oct 2015
    many thanks for that bot of info will give it a go
    V.I.P. Member haribo's Avatar
    Jun 2008
    in my car
    Quote Originally Posted by marko12 View Post
    I am currently out of office on the phone to me that the small
  10. #9
    Top Poster Chalkywhite's Avatar
    Hi My mate has a xtrend 9000 and is having a problem with *time out for tuner lock* when running cross epg downloader.. he has the settings set up exactly the same as mine but im not getting this error.. strange. any ideas appreciated.
  11. #10
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    You should be able to find the answer from lincsat on post 2 start with checking signal on tuners and the connections into box and lnb are good.
  12. The Following User Says Thank You to DOUGALMCD For This Useful Post:
    martin035 (3rd September, 2016)
  13. #11
    Jun 2008
    Quote Originally Posted by Chalkywhite View Post
    Is this for Cable? This is the Cable TV section
    If so, then you're best using EPG Importer for Cable EPG. The Open TV for 28e certainly will not work for Cable
  14. The Following User Says Thank You to lincsat For This Useful Post:
  15. #12
    Sep 2016
    U.S.
    I m interess to test the firmware but i dont know if i have DM800se-v2 or DM800SE, how i can check it? Best Regards.
