little bit oh help
autobouquetsmaker timeout for tuner lock open droid 4.1 sunray sr4 a8p
little bit oh help
No signal, poor signal, wrong region selected, incorrect tuner config
many thanks for you quick reply signal is good just put my zgemma star h2/t2.c with open vix all channels working net id 00004//frq 755 provider sky hd wales/virgin uk still no joy is there a better image out there to us for sunray sr4 a8p
regards
beano2
haribo (30th July, 2016)
Is the Sunray a single Cable tuner or the Triple tuner. If the Triple tuner, then you need to set it up differently. BTW, the Default or EPG frequency is 643MHz, SR=6887, QAM=64 for Pure NTL areas. Try a manual scan on that frequency and see if you have a signal
hi it a sunray sr4 a8p Triple tuner you can see the 3 tuners ive got 28.2 its cable side i just change the setting to the one in your post but sill nothing found
The Triple tuners need setting differently, you can't use ABM as you have to change the frequency. You will need to do a Google search to find the procedure, I just found it in seconds. This is part of it
You may also be able to edit the Lamedb or satellites.xml, I last had one about 5 Years ago, it was a pain to setup but did work.The main thing you have to remember here is the frequencies you enter needs to have a 01 in front of it. So if a frequency for your area is 643.000 you loose the 000 from the end and put a 01 in front of the 643 so you end up with 01634 in the frequency entry. For the symbol rate you need in most cases a zero in front so 6667 will be entered as 06667.
many thanks for that bot of info will give it a go
Hi My mate has a xtrend 9000 and is having a problem with *time out for tuner lock* when running cross epg downloader.. he has the settings set up exactly the same as mine but im not getting this error.. strange. any ideas appreciated.
You should be able to find the answer from lincsat on post 2 start with checking signal on tuners and the connections into box and lnb are good.
martin035 (3rd September, 2016)
I m interess to test the firmware but i dont know if i have DM800se-v2 or DM800SE, how i can check it? Best Regards.
