Page 11 of 127 FirstFirst ... 6789101112131415162161111 ... LastLast
Results 151 to 165 of 1900
  1. #151
    Greece
    Quote Originally Posted by rob h View Post
    The machine is inside, where it is nicely warm.
    And the machine is getting out of the calibration mode quicker.
    But Every time i send a command by USB, is goes to calibration mode.
    I remove the 3 custom Keys, and reset everything.
    Reloaded latest v2.3.3 again.
    But still it is slipping in to calibration mode after any USB command, and sometimes after just turning the machine on.
    Xhorse support is not pitching in yet!
    So i will try to skype condor_keymachine@hotmail.com
    Unfortunately i think this is hardware problem. Only x horse can help you
  2. The Following User Says Thank You to kleidaras For This Useful Post:
    rob h (20th January, 2017)
  3. #152
    AndyCZ's Avatar
    Jan 2014
    EU
    Quote Originally Posted by paul_12345 View Post
    can't open your file... but had another look at the pics and you've entered the cut depths backward
    file opening ok with condor sw. You chose import, select file, done.
    Reversing cut depths looks this.
    If I helped you know what to do..
  4. #153
    Quote Originally Posted by AndyCZ View Post
    I have big condor and tried downloading a version of the mini software but it still takes .u files... I removed the first 6 bytes from the file then it opens in the .u version.
    Have you put the key as 4 track?
    unless this has opened wrong...
    Key should be channel track.
    you have tip cuting at 5, this is 0.01mm so 5 is nothing, I woulld also have b on the first option set back like the top.
    The flats should be 50 as per instacode.
  5. #154
    Jul 2015
    Is cutting HU56 (Mitsubishi/Volvo) still not OK as it was mentioned on early pages?
  6. #155
    rob h's Avatar
    May 2011
    Check what version failed,
    After hooking up your condor, and press update option, a window shows keys added and fixed.
    Quote Originally Posted by gokart View Post
  7. #156
    AndyCZ's Avatar
    Jan 2014
    EU
    MB Trucks / VW LT old model YM15 bug in SW.
    1. Need add cutting depth 6x+
    2. Cut key blade head about 2mm when cutter goes to other key side.
  8. The Following User Says Thank You to AndyCZ For This Useful Post:
    rm23 (2nd February, 2017)
  9. #157
    check the length of the blade from the shoulder... think you will find the one you cut is longer than it should be.
  10. #158
    AndyCZ's Avatar
    Jan 2014
    EU
    31mm
    Volvo HU56R cut depth must set -0.55mm then it's OK.
    Samic please fix issue:
    1. Renault Key Card.
    2. MB YM15.
    3. Volvo HU56R.
  11. The Following User Says Thank You to AndyCZ For This Useful Post:
  12. #159
    rob h's Avatar
    May 2011
    Keys in clamp A turn a bit whilest clamping them in.
    Elevating the left side.
    This will enhance this cutting depth, causing your problem.
  13. #160
    Norfolk england
    Plastic emergency keys is there a way to cut these. With condor.
    Add life to your days not days to your life
    P
  14. The Following User Says Thank You to purdy For This Useful Post:
    srec1503 (15th February, 2017)
  15. #161
    AndyCZ's Avatar
    Jan 2014
    EU
    Quote Originally Posted by purdy View Post
    1. Decode key.
    2. Put metal blade.
    3. Press "Cut".
    4. Wait until probe touch the blade.
    5. Press "Stop".
    6. Change to plastic blade.
    7. Press "Resume" - Start.
    8. Done.
  16. The Following 3 Users Say Thank You to AndyCZ For This Useful Post:
    Jobeso66 (16th October, 2017), Nassreddine84 (21st February, 2017), purdy (12th February, 2017)
  17. #162
    May 2013
    Don't forget to set Cutter Axis Speed to Max and the Spindle speed to MIN. If your speed too high then it melts the plastic.
  18. The Following 2 Users Say Thank You to obeids For This Useful Post:
    clintezra (15th June, 2017), purdy (12th February, 2017)
  19. #163
    May 2013
    I have a problem with the HON66 Keys......
    Is it me or is it these Computerised machines?
    If I duplicate a key it works perfect as long as the key wafers aren't worn out (These wafer are problematic).
    However if I cut a key from numbers on wafer inside lock (No Master key available) then I end up with a problem. The problem is that it seems that the last row (tip of key) wafers are cut as per the second row. Thus starting from the left of the going to the right, I have to drop the wafer on most right and then shift all wafers 1 position forward and match the most LEFT wafer with something else.
    If I remember this lock has 6 wafers on each side. I enter the numbers exactly as found in the lock but when it cuts then it cuts the key with all the wafers moved up 1 position. Thus the 6th wafer it cuts according to position 5 wafer's depth.
    ACTUAL POSITIONS
    ROW A ........ ROW B
    1 = 3 ............1 = 3
    2 = 4 ............2 = 2
    3 = 4 ............3 = 2
    4 = 3 ............4 = 3
    5 = 2 ............5 = 4
    6 = 1 ............6 = 1
    When Cut
    ROW A ........... ROW B
    1 = ? ..............1 = ?
    2 = 3 ..............2 = 3
    3 = 4 ..............3 = 2
    4 = 4 ..............4 = 2
    5 = 3 ..............5 = 3
    6 = 2 ..............6 = 4
    This same problem I had on the X6 key cutting machine.........
    Any solution? Did anybody else have the same problem?
  20. #164
    rob h's Avatar
    May 2011
    And do not clamp plastic keys in with to much force!
  21. The Following User Says Thank You to rob h For This Useful Post:
  22. #165
    rob h's Avatar
    May 2011
    KeyData.rar
    Hello Obeids,
    Replace the file in your customkeytools with this file.
    You can adapt the tickness, and internal with if neccasary.
    And the shoulder, from position 1 to the keys head, is cut narrow.
    You might not be able to do that with my file. So:
    Precut a key, using the condors own hon66, A111111 b111111.
    Then use the Hon66x key, and cut key.
    Does your machine have the latest vesrion software?
