Mercedes Sprinter
Mercedes Sprinter
Hard to turn 1: A lott off resistance in every position. Key cuts are not deep ennough. Shims are jammed.
Hard to turn 2: A lott off force to get a turning movement started, and then it snaps, and the movement is light. Cuts are to deep.
Hard to turn 3: A lott off resistance in every position. Cuts are not in the correct position. And this jams some shims by the concave profile between the cuts.
Measure the dephts, if these are 100%. Then you might have choosen the wrong Type Hu64.
Option 3: Cuts are not in the right position!
Look for markings ( impressions ) left by the shims on the cut profile.
clintezra (15th June, 2017)
This is the tab tab that I use in Renault key card blades so it works fine once I add .20 of depth to the cut...
however in the emergency blades I have to file the tips flat for it to work properly it doesn't like the pointy tips!
Does anybody body have problems with va2/6 blade cutting! Or is it my decoding skills with the pick!
Condor XC-MINI latest version V4.0.1 update
V4.0.1(2017.06.16)
+Add universal key decode function
+Add M2-D function
+Add motor sensor testing function
*Modify probe/cutter detection
*Fix machine may crash error problem
*Fix HU49 key decode error
*Fix HU66 cutting speed issue
*Fix BW6 cutting error
*Fix TBE1 cutting error
Notes:
1.New update for both SN KM02/KM03 machines
2.New function:Main Interface--Key Duplication---Universal Type
3.Universal Type support decode/cutting parts of home & vehicle keys
4.Please keep the whole key clean and conductivity good(ensure without dust/oil)
5.For one side key(thickness of whole key usually 1.5mm or 2.00mm) please add a shim/business card under the key,
ensure the whole key thickness should more than 3mm.
any problem post here/PM me.
Samic, how is it possible to cut home keys? I assume there must be new clamp developed?
If I helped you know what to do..
fytfh (20th June, 2017)
AndyCZ (16th June, 2017)
Yes I also agree. Also renault card emergency key cut not complete, we reported this about four months ago. No reply and solution so far. Two updates passed just ignoring these issues.
daxxer (20th June, 2017)
I'm not talking about thickness cut, this is known issue. Check this.
Has anyone got the hang of using the H1 Key Holder, I had some issues doing a Mazda Key, I will post some pictures.
h1????
whats that?
