>>>>>>>>>>>>>>CONDOR KEYCUTTERS <<<<<<<<<<<<< - Page 2
Page 2 of 127 FirstFirst 12345671252102 ... LastLast
Results 16 to 30 of 1900
  1. #16
    Norfolk england
    Hi Samic
    I have a chance of buying a SH lishi machine I think this is a rebadged condor 007 are you still supporting updates on this machine as I know it is out of production.
    purdy
    Add life to your days not days to your life
    P
  2. #17
    Wegrow, Poland
    Please add Renault Clio III 2006- key VA2T
  3. #18
    CaioW's Avatar
    Oct 2015
    Everywhere
    Guys we have some problems today to cut one HU64 from Mercedes.
    When we put the key into the jaw, the jaw dont make prober pression and the key moves around.
    Did you guys noticed this? Or i'm doing something wrong?
    edit: Talking about minicondor
  4. The Following User Says Thank You to CaioW For This Useful Post:
    chaoui05 (2nd September, 2016)
  5. #19
    lpf01's Avatar
    Oct 2013
    I cut some HU64 and never had a problem with it.
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
  6. #20
    rm23's Avatar
    UK
    Quote Originally Posted by lpf01 View Post
    I can confirm that with my machine, all fine..
  7. The Following User Says Thank You to rm23 For This Useful Post:
    tinerfe30 (21st February, 2017)
  8. #21
    CaioW's Avatar
    Oct 2015
    Everywhere
    Look the video we made.
    The key dont make proper pression..
    I'm doing something wrong?
  9. #22
    lpf01's Avatar
    Oct 2013
    Dear Samic
    I found that if i cut a double sided key ( SZ12, SZ11, GT15R and so on) , and need to do some correction and i want to cut it second time, first cutted side is always have undercut, second dont.
  10. #23
    Quote Originally Posted by CaioW View Post
    It looks like the line it tells you is not inline with the clamp but slightly in... if not I assume the mini is like the xc007 and touches the tip of the key for alignment on most keys in which case just dont put it as far in.. simple
  11. #24
    CaioW's Avatar
    Oct 2015
    Everywhere
    Quote Originally Posted by paul_12345 View Post
    If we dont put in the position, the machine dont read the key
  12. #25
    Dec 2010
    Hello, I need help I have mini condor key machine, and can't work with M3 clamp, can't decode or cut any SX9 key. Need any additional configuration for use this clamp? Thanks
  13. #26
    Any USA Seller for this condor machine? Please PM me.
  14. #27
    Apr 2015
    Quote Originally Posted by fabi View Post
    Please try to select 'Cut By Bittng'---enter 'VA2T' enter bittings or decode key,then cutting.
  15. The Following User Says Thank You to Samic For This Useful Post:
    daxxer (30th August, 2016)
  16. #28
    Apr 2015
    checked the video,please update (2.1.2version)again first,then put the key into clamp proper position,pay attention to 'Align Line',HU64 should be in'second' line.
  17. The Following User Says Thank You to Samic For This Useful Post:
  18. #29
    CaioW's Avatar
    Oct 2015
    Everywhere
    Quote Originally Posted by Samic View Post
    checked the video,please update (2.1.2version)again first,then put the key into clamp proper position,pay attention to 'Align Line',HU64 should be 2nd line.
    Yeah buddie, but my machine is in the version 2.1.2 and the machine tell me to put into the 1st line, not the 2nd. And if i put into the 1st line need to regulate manualy until get the point where machine starts to decode the key. I'm just saying that much because does keys are pretty ~~~~ty and if one cut goes little little little wrong, the key dont work.
    And at this point idk if it is my fault or what..
  19. The Following User Says Thank You to CaioW For This Useful Post:
  20. #30
    Apr 2015
    Dear Samic
    after decode key,if you wanna modify some bittings,you can change bittings directly,then select 'correction & cut',not 'cut' directly.
  21. The Following User Says Thank You to Samic For This Useful Post:
