>>>>>>>>>>>>>>CONDOR KEYCUTTERS <<<<<<<<<<<<< - Page 33
Page 33 of 127 FirstFirst ... 2328293031323334353637384383 ... LastLast
Results 481 to 495 of 1900
  1. #481
    Sep 2017
    Quote Originally Posted by gokart View Post
    It's a common VA2 for PSA. It isn't custom. I attached a high resolution photo. If you see that area what I mentioned in my previous post you can see two different curve.
    1. straight line - it is the top layer (low depth)
    2. correct curve - lower layer (high dept up to 1mm)
    The straight line cut the top of the correct curve.
    I am running your key cut in my condor mini. Same issue. It seems file is not accurate. I am afraid it needs to be corrected. See picture attached
  2. #482
    Sep 2017
    Other quick solution is to create a custom key on the Key edit area A HY18 cuts 1 depth deeper so I created one for my a couple days ago. If your are not familiar with custom keys. Let me know I can help you
  3. #483
    Sep 2017
    I had problem today with cutting VA2 for PSA. See the photo. I cut F C A A E A. The problem is at 1055-790. It mustn't be a straight line at the bottom.
    Condor mini KM03 cuts a straight line for the top layer then cuts correctly at the deeper layer. The cutting curve isn't the same for the 1 mm depth. It looks like a worn key after cutting. I ask the developers to check it.
    What is MACS specs for this key? I mean it jumps 4 depths from a A to a E.
  4. #484
    Sep 2017
    Please ignore this blank key , take a look at my key cut. It will come in and out Smoother, . Wafers will sit on the right position , it won't affect its key Opening way ,
  5. #485
    Sep 2017
    Quote Originally Posted by Jobeso66 View Post
    Never mind
  6. #486
    Sep 2017
    i. I changed cut #5 to a "A" See results.
  7. #487
    Oct 2017
    Thank you,we have revised gokart's va2 problem.Just need to update when the version is ready(it's processing).
  8. The Following User Says Thank You to Xhorsesupport For This Useful Post:
    gokart (13th October, 2017)
  9. #488
    rob h's Avatar
    May 2011
    Probe to high.jpgTo comment on you first cut key, your probe seems to be to high.
    It needs to touch the tip, not the rounded area of the tip.
    This causes the cuts to be of place.
    Or try this,
    ic card 1125
    cuts 174828
  10. #489
    Default Toyota Aygo KEY
    how do i cut this key with my condor.
    key code - B1765
    intacode - QH72HQ
    not sure how to do this....help!
    DJ
  11. #490
    Oct 2017
    Enter into the "key database",select Toyota,input key code B1765,then cut
  12. The Following 3 Users Say Thank You to Xhorsesupport For This Useful Post:
    djollie (13th October, 2017), Jobeso66 (13th October, 2017), PremierD (13th October, 2017)
  13. #491
    May 2013
    Hi there
    Seems I am having an electrical conduct issue on my machine....
    Many times when I tell the machine to start cutting after decode or even after manually entering bittings it will move a little then stop and at the bottom of the screen says..."PROBE DETECTED".
    Sometime It starts cutting after 3rd attempt. Sometimes works first attempt.
    I also have a problem decoding some HU92 keys. It sometimes just won't decode correctly.
    In the past month it has snapped 2 decoder points. One was on the VA2 key but LOUIS21 says it must be dirt on the key.
    The other other day I wanted to cut a FO21 (Ford Tibbe) and I clamped in the key and all ready to go. I press start and it goes to measure the key as it usually. It touched the key and the mioved to the clamp and continued all the way breaking the Decoder tip. No Dirt at all. It's shining clean. I then noticed on the key where the decoder touched, a notch, meaning that the decoder pressed very hard onto the key and probably didn't sense the key correctly.
    This problem is intermittent. When I run the Electrical conductivity test it seems fine, but bear in mind that when doing test the Motor isn't moving front and back. The problem seems to rise it's head when the motor moves front and back that it looses conductivity / gets false conductivity.
  14. #492
    Sep 2017
    Quote Originally Posted by weza247 View Post
    Does Condor Mini have this function
    kia hy20 right hand blade
    Were you able to find it?
  15. #493
    Sep 2017
    Quote Originally Posted by sleepyrz View Post
    Alright I think I got that figured out now too
    Were you able to to cut hu100 10-cuts without any problems , ? I found a solution recently playing with cóndor mini
  16. #494
    Oct 2017
    Quote Originally Posted by obeids View Post
    Hi there
    Motor test Y can't work every time?that's maybe the problem of it.
  17. #495
    Jan 2017
    USA ����
    yes i just make a custon key file for hu100 10 cut
    and cut by input direct bitting
    or trace with hu100 8 cut and figure out last two cut then use custom key filefor 10 cut
  18. The Following User Says Thank You to sleepyrz For This Useful Post:
    Jobeso66 (4th November, 2017)
