Page 34 of 127 FirstFirst ... 2429303132333435363738394484 ... LastLast
Results 496 to 510 of 1900
  1. #496
    Mar 2009
    I have recently purchased an XC-mini, and I'm pleasantly surprised by it. Its much better than I was lead to believe!
    Has the Renault keycard blade cutting been fixed, or is there a solution by making a custom file? It cuts the opening V incorrectly as mentioned earlier in this thread. I tried making a custom file, but dont know how to correct the opening V part of the key specification.
    Also, is the custom file specification available anywhere ? It would encourage alternative software if this were available along with the communication specification over USB.
    Thanks.
  2. #497
    Jan 2017
    USA ����
    The cutting for the v0001-v5000 code series for the 10 cut keys hu100 is bad
    The tip is wrong and the depths are wrong
    Good thing I made a custom key file for the 10 cut
  3. The Following User Says Thank You to sleepyrz For This Useful Post:
    Jobeso66 (4th November, 2017)
  4. #498
    Jan 2017
    Quote Originally Posted by sleepyrz View Post
    Mind sharing it? ��
  5. #499
    Oct 2017
    Quote Originally Posted by madaxe View Post
    Thanks.
    It is ready next update.About how to make a custom file,following file for reference,hope that can help you a little.
  6. The Following User Says Thank You to Xhorsesupport For This Useful Post:
    kostas (3rd November, 2017)
  7. #500
    Mar 2009
    Hi, thanks for your reply, but its not clear what you are saying.
    "It is ready next update." It can mean the next update is now ready to download, or that the things I've asked for are in the next update, but it is not ready to download. Can you explain which it is please ?
    I understand how to make a custom key file, your software is very good in that respect and as I described, I have done this. With my custom key file, the machine cuts the channel almost correctly, however, as I described the tip of the key where the opening V is cut, is not cut correctly. It has been described with photos in this thread earlier from post #399, though I only just read there is a universal copy tool, I'll try that but doesnt help if I need to cut the key to a lock I decoded. So needs to be fixed. Maybe have a couple of options in the software for how wide the V at the tip needs to be ?
    And regarding the custom key file specification and the communication over USB ? Any chance that will be available to developers and interested parties soon ? That would certainly help people develop software compatible with your machine.
  8. #501
    Sep 2017
    Quote Originally Posted by Jobeso66 View Post
    Were you able to find it?
    Yes I have. Thank you
  9. #502
    Apr 2016
    USA
    Need some help tried to cut a key for 2013 VW CC also Passat 6B Believe is same key.
    All keys are only plastic, my issues was everytime I have my machine xc007 trace key, the trace bit would snap, I never Seen that before, I snapped three trace bits in row.
    Is there issue with machine? Or somejing xhorse knows about?
    I did last big update, not sure if more updates where made since then.
    Just trying to find out if anyone else’s experienced this issue.
  10. #503
    Greece
    Machine work with electric contact. On plastic key not have electric contact and tracer brake. All machines work like this.
    Στάλθηκε από το F3311 μου χρησιμοποιώντας Tapatalk
  11. The Following 2 Users Say Thank You to kleidaras For This Useful Post:
    BRMTDI (6th November, 2017), kronk92 (6th November, 2017)
  12. #504
    Jan 2017
    USA ����
    Quote Originally Posted by BRMTDI View Post
    Decode by eye if you have old key or by lishi if no key
    Insert hu66 metal key
    Input code you got
    Start the machine so it calibrates on the metal key and just when it is about to start cutting
    Press pause and pull out metal key blade and swap in plastic blade
    press pause again to continue
    This is how I do it
    The problem with the machine in this case is you not knowing enough about how it works
  13. The Following User Says Thank You to sleepyrz For This Useful Post:
    BRMTDI (9th November, 2017)
  14. #505
    Oct 2017
    The "Renault" opening V cut incorrect,engineer has revised it and will upload the modification soon.I'll let you know when the revise is uploaded,at that time you just need to update the condor.Any problem please feel free to contact with me,thank you.
  15. The Following User Says Thank You to Xhorsesupport For This Useful Post:
    madaxe (7th November, 2017)
  16. #506
    Jul 2015
    Input code you got
    This is how I do it
    It is unnecessary to insert metal HU66. Just insert plastic HU66 to cut it.
  17. #507
    Feb 2014
    Quote Originally Posted by gokart View Post
    If you want to brake your sensing probe or the cutter - yes, you can do it without putting the metal key first...
  18. #508
    Jul 2015
    Quote Originally Posted by autoTkey View Post
    ...nope, it can't damage anything in case of HU66. If Condor doesn't touch the key blade before cutting you can put directly the plastic key.
  19. The Following User Says Thank You to gokart For This Useful Post:
    autoTkey (7th November, 2017)
  20. #509
    Cutter touches the top of the key for reference height on a hu66
    Sent from my SM-G930W8 using Tapatalk
  21. #510
    Jul 2015
    Quote Originally Posted by dmp View Post
    It doesn't check the height of the HU66 key. The first video what I found about it: https://www.youtube.com/watch?v=lSGS70bFEBo
