Page 39 of 127 FirstFirst ... 2934353637383940414243444989 ... LastLast
Results 571 to 585 of 1900
  1. #571
    wissamshaat's Avatar
    Oct 2017
    france
    so now we have to wait for an update to the va6 keys?
  2. #572
    Oct 2017
    france
    Oh my god
    New problem
    I puted a pin code for the machine and the code was 1951 .. now when i want to enter the menu and i put 1951 and ok
    Nothing happen
    Help pleass
  3. #573
    Oct 2017
    france
    I found it
    Its 123456 default code
  4. The Following User Says Thank You to wissamshaat For This Useful Post:
    Alice (17th November, 2017)
  5. #574
    Question
    When i try to update minicondor to 4.0.2
    1. file (firmware)update ok
    2. file (sd) start and get error
    mashine start but when chose something on screen is big mees.
    I put sd card in mashine and try update again but same.
    Sd card must be formated or prepared to mashine recognise?
    Or update kit is problem?
  6. #575
    Jan 2017
    USA ����
    update by usb
  7. #576
    Nov 2017
    Quote Originally Posted by wintesla View Post
    Question
    V4.0.2 software is available now, confirm with factory, the newest software they offer is still v4.0.1, where did you get the v4.0.2?
  8. #577
    Quote Originally Posted by sleepyrz View Post
    update by usb
    I update by usb and get this error when start 2. file
  9. #578
    Oct 2017
    france
    Quote Originally Posted by Giuseppe Mark View Post
    thats the update 4.0.2
    http://www.digital-kaos.co.uk/forums...7&d=1510658377
  10. #579
    Oct 2017
    france
    probe brocken when i wanted to decode this key
    from the first touch to the key
    why thiss happen?
  11. #580
    Oct 2016
    Scotland
    Quote Originally Posted by wissamshaat View Post
    why thiss happen?
    Looks like a plastic key!
    The tracer probe works on conductivity, so if it doesn't detect a metal key it will keep moving and break probe.
  12. The Following User Says Thank You to WRX 14 For This Useful Post:
    wissamshaat (17th November, 2017)
  13. #581
    Oct 2017
    france
    oh realy
    i didnt knew that thank you
  14. #582
    lkjubaking's Avatar
    Feb 2013
    Serbia
    yes that right answer
    i brocken 2pcs probe with this key and after that i understood how xc-002 work
    DPF/EGR-OFF , TUNE , FLAPS/SWIRL-OFF , DTC-OFF........
  15. The Following User Says Thank You to lkjubaking For This Useful Post:
  16. #583
    rob h's Avatar
    May 2011
    Put in a metal key first.
    Start cutting, pause, switch to plastic, and proceed with the cutting.
  17. The Following User Says Thank You to rob h For This Useful Post:
  18. #584
    Oct 2016
    Scotland
    Yes, that works for cutting new key, however for decoding the plastic key that he is trying to do, it won't work on the machine.
    Will need to decode by eye.
    Only putting that statement up incase he misread your comment and try to decode again following your step, and break another tracer probe
  19. The Following User Says Thank You to WRX 14 For This Useful Post:
  20. #585
    Oct 2017
    france
    thank you all
    i will buy other probe and some drills
    i had a code with that key to.when i tried to put the code it worked and showed me the same cut
    but i did that only for trying and training
    i didnt started to cut keys for custumers yet i am now in training only
    and with the help of you all i will be good
    thank you againe
