Page 3 of 127 FirstFirst 123456781353103 ... LastLast
Results 31 to 45 of 1900
  1. #31
    Apr 2015
    Quote Originally Posted by jacostanzo View Post
    Hello, I need help I have mini condor key machine, and can't work with M3 clamp, can't decode or cut any SX9 key. Need any additional configuration for use this clamp? Thanks
    M3 clamp not need calibration,directly use.it cannot decode key,shoud enter bittings by manual then cutting.if still cannot work let me check for you.
  2. The Following 3 Users Say Thank You to Samic For This Useful Post:
    CaioW (2nd September, 2016), daxxer (30th August, 2016), PremierD (2nd September, 2016)
  3. #32
    Apr 2015
    Quote Originally Posted by CaioW View Post
    Yeah buddie, but my machine is in the version 2.1.2 and the machine tell me to put into the 1st line, not the 2nd. And if i put into the 1st line need to regulate manualy until get the point where machine starts to decode the key. I'm just saying that much because does keys are pretty ~~~~ty and if one cut goes little little little wrong, the key dont work.
    And at this point idk if it is my fault or what..
    please update again(2.1.2),this bug fixed just now and already released.database issue,thanks for your feedback with video.
  4. The Following 2 Users Say Thank You to Samic For This Useful Post:
    CaioW (30th August, 2016), daxxer (30th August, 2016)
  5. #33
    CaioW's Avatar
    Oct 2015
    Everywhere
    Quote Originally Posted by Samic View Post
    Thats PERFECT will try now and report.
    Thank you Samic, the best!!!
  6. The Following User Says Thank You to CaioW For This Useful Post:
  7. #34
    Wegrow, Poland
    Please try to select 'Cut By Bittng'---enter 'VA2T' enter bittings or decode key,then cutting.
    HI.
    OK. I know this.
    Please add Renault Clio III 2006- key VA2T in next update.
  8. #35
    Wegrow, Poland
    HU56R cutting is bad. HU56R key thickness is 3.5mm. Silca, JMA, Errebi keys thickness are 3.5 mm. Please check it.
  9. The Following User Says Thank You to fabi For This Useful Post:
    haiz0708 (10th September, 2016)
  10. #36
    lush29's Avatar
    Oct 2015
    Someone is using this machine in the van? Is good heavy duty? Thanks
    Sent from my SM-G925F using Tapatalk
  11. #37
    Apr 2015
    canada
    hello samic i have a mini condor...im having a big problem for cutting keys for mercedes hu64 blade
    it always cuts wrong..
    i have tried also cut bitting still no luck
    on diagram it shows place blade on m2 and close to line but, as you know the keys are narrow it can never align close to line always push itself back
    i have tired cutting several hu64 no luck at all
    rest is fine so far
    only hu64 mercedes
    please advice what to do,
    if there is a special type of adapter needed let me know....
  12. The Following User Says Thank You to infotech For This Useful Post:
    purdy (4th September, 2016)
  13. #38
    rm23's Avatar
    UK
    100% hu64 is ok with condor xc007 and condor mini tested by me many times...
  14. The Following User Says Thank You to rm23 For This Useful Post:
    daxxer (3rd September, 2016)
  15. #39
    May 2013
    Hi there
    Recently got the Condor Mini.
    Seems good. However if the dust cover could have been designed a bit away from key it would've been nice. Currently the problem is most keys will touch on dust cover when cutting. Some key like VW Flip key cannot let the cover be closed. So if cover is open then what is the purpose of dust cover because dirt goes everywhere.
  16. The Following 2 Users Say Thank You to obeids For This Useful Post:
    daxxer (4th September, 2016), rm23 (3rd September, 2016)
  17. #40
    Apr 2015
    canada
    Quote Originally Posted by rm23 View Post
    hello sir please guide me
    what m i doing wrong
    i have cut few s class
    ml
    clk
    all hu64
    it always cut wrong using m2 adapter i follow every step on screen...
    i dont understand cut by bitting
    there is a option
    hu64 -2
    hu64 -3
    how should i place key close to line when i tight the clamp the blade always move alittle back of line ....
  18. #41
    CaioW's Avatar
    Oct 2015
    Everywhere
    Quote Originally Posted by infotech View Post
    ml
    clk
    all hu64
    there is a option
    hu64 -2
    hu64 -3
    This still a BUG to fix..
    You need to put the key at the 2nd line to work, not in the 1st. Even if the machine told you to put in the 1st.
    I have the same bug on my machine.
  19. The Following User Says Thank You to CaioW For This Useful Post:
  20. #42
    Moderator
    PremierD's Avatar
    Jun 2009
    The database needs amended .. to show where in actual fact you put the key but its common sense really, it cannot clamp firmly if it is not a uniform width so either file the high spot of the key .. or do as suggested move it further back
  21. The Following User Says Thank You to PremierD For This Useful Post:
    purdy (23rd September, 2016)
  22. #43
    Apr 2015
    canada
    ok sir i will do that and report that...tommrow.
  23. The Following 2 Users Say Thank You to infotech For This Useful Post:
    CaioW (5th September, 2016), daxxer (11th September, 2016)
  24. #44
    CaioW's Avatar
    Oct 2015
    Everywhere
    And the option "Cut by bitting" you can chose manually HU64, but in the end its the same database..
  25. The Following User Says Thank You to CaioW For This Useful Post:
    daxxer (5th September, 2016)
  26. #45
    Apr 2016
    Ok I have a SX9 Key
    the cuts on the top edge (as opposed to the side edge) have little cuts in them... (think half moon)
    whilst the original key has a long low cut into it... in theory it should work, if depths are right...
    But it doesn't work! And it wont decode either... Is there update soon Samic.
    Mc
