yes there is but i need to have others for emergency.
by the way i found 1mm and 2mm tracers on sell why and for what the 2mm is used?
and the 2 mm drill to?
thank you
thank you
yes it is genuine
hello againe freinds
what is instacode sertefication that must given from condor
i didnt recived one and how it works with bluetooth?
thank you
The instacode certificate is to get 1 year free access to the instacode live website/app
I never received one with my machine either, and was never able to get any support from Xhorse in retrieving a certificate.
wissamshaat (18th November, 2017)
decode those with verniers-Ive actually cut on a blank metal blade a key with each of the cuts to base my measurements from
Sx9 not work. Side cuts is ok but normal cut no. Machine need cut little more on the front.
Need cut this i mark on the photo
If not pin go like this on the key
For work need cut it 2 time. One time normal and ufter this i put a uncut key and ufter machine measure this key before start cutting i press pause and i put first key but i keep it little back.
The key i have at the end is like this
The code for this key is 16861
Στάλθηκε από το F3311 μου χρησιμοποιώντας Tapatalk
