Page 42 of 127 FirstFirst ... 3237383940414243444546475292 ... LastLast
Results 616 to 630 of 1900
  1. #616
    auto techniek's Avatar
    Mar 2017
    I m intetessted buying this device.
    Does anyone know if i can get discount because i already have vvdi MB tool?
  2. #617
    Feb 2014
    It's the other way - you get discount for VVDI MB tool and some addons for VVDI2 if you got the Condor before that, not after.
  3. The Following User Says Thank You to autoTkey For This Useful Post:
    auto techniek (20th December, 2017)
  4. #618
    Jun 2013
    This is for Samic, or the rest of the team.
    __________________________________________________ _______________
    Why is the bundle with Mini Condor only available with MB tool.
    Why not bundle with Mini Condor and VVDI2 Full?
    And as I have mentioned before, without any feedback.
    Are there any plans at the moment, for developing an even smaller full automatic machine?
    12V battery with no screen.
    Bluetooth and USB cable to machine for control and update.
    Everything controlled by APP - on mobile phone or some Pad - Ipad - Android.
    __________________________________________________ ________________
    Thank you for any feedback in these questions.
  5. #619
    Feb 2014
    I think the FEM update for VVDI2 has a price depending on whether you have Condor or not. It's cheaper if you give them a Condor SN.
  6. #620
    Jul 2015
    Quote Originally Posted by autoTkey View Post
    Yes, it is cheaper with Condor.
  7. #621
    In EEP
    Hi i have read post About Mercedes HU 64 but i cant cut working key . Can me someone calculated key for trying .
    I try hu64 all hu64-3 hu64 -T but not luck
  8. #622
    Jun 2014
    Quote Originally Posted by vasa View Post
    maybe 4234331355.
    i use cut by bitting function hu64-3
  9. The Following User Says Thank You to dustin2014 For This Useful Post:
    vasa (24th December, 2017)
  10. #623
    Jan 2017
    USA ����
    weird i only use regular hu64 and it works perfect for me
  11. The Following User Says Thank You to sleepyrz For This Useful Post:
  12. #624
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    what type of blade you want to use for cut ???
    its depend of this first....after set right type and cut...for me work everytime success
    many thanks to friend kevfield
  13. #625
    lpf01's Avatar
    Oct 2013
    Quote Originally Posted by sleepyrz View Post
    weird but mine too, even i dont fit blade properly just pust in to the clamp until it goes and after that change to different hu64 blade ( like old motorola mercedes key blade to new bga or something....)
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
  14. #626
    Quote Originally Posted by lpf01 View Post
    I don't understand very well to all of you in this case... I always cut well the key, the problem is the key doesn't enter in the keychain because of the top of the key. I realized always bga keys are a little smaller than nec black keys and/or motorola keys, and then I cut a little the top of the key and then works very well... If you have any other trick, would be better to explain to me, thanks!!!! (will post photos to see what I'm saying)
    Also,
    Happy Christmas!!!!
    Enviado desde mi SM-G955F mediante Tapatalk
  15. #627
    Feb 2014
    No other trick - problem is in the key itself. Needs to be manually corrected, otherwise it doesn't get fully in the lock as you already noticed. You can push it hard in the lock once and after that it will work easier, but that's a bit risky.
  16. #628
    Oct 2017
    hello mate,about the benz hu64 keys,you have the key,so try to copy it firstly.The hu64,hu64-2,hu64-3 have some difference on the first bit to the top of the key,the distance of HU64 option from tenth bit to the top is 580,HU64-2 is 450,HU64-3 is 380.So if the tenth bit is the same 1,but you choose different options,then you can see the gradient at the top is different.the gradient of HU-64 is the smallest,HU64-3 is the biggest.I attached a photo,hope that help you
  17. The Following User Says Thank You to Xhorsesupport For This Useful Post:
    vasa (3rd January, 2018)
  18. #629
    Jan 2017
    USA ����
    so why are there three of them
    and when do you use each one..........
    ive only ever used hu64 on all the keys ive ever cut for mercedes
  19. #630
    rob h's Avatar
    May 2011
    If there is no old keyblade,
    The choose the HU64-3, it will open most cars.
    And cut position number 1, will stop the blade from entering to deep, instead of the tip.
  20. The Following 3 Users Say Thank You to rob h For This Useful Post:
    comizelu (31st December, 2017), PremierD (31st December, 2017), WRX 14 (6th March, 2018)
