Page 43 of 127 FirstFirst ... 3338394041424344454647485393 ... LastLast
Results 631 to 645 of 1900
  1. #631
    Mar 2009
    Hi, today I updated XC-mini KM03 from 4.0.1 to 4.0.3 using USB cable and PC software Upgrade Kit v1.1.9. Took about 20 mins to do and XC-mini seems to boot ok. However, if I try to connect PC to XC-mini again, it does not connect. I click on find device button, software says Error: Failed to read device info. XC-mini changes to black background screen with Condor, XHorse logo and serial no. Does not display firmware and does not change, even with USB cable removal. Need to power cycle the XC-mini, then back to light screen with main menu. I can see XC-mini firmware is 4.0.3 here. Hopefully machine works ok, and next update software will at least communicate with XC-mini.
  2. #632
    Jul 2015
    I haven't upgraded yet to 4.0.3 since I didn't get any answer what was changed in that version. Now, I'm not planning to perform this upgrade at all.
  3. #633
    Mar 2009
    The one change that I needed was renault keycard emergency key. I got PM from XHorsesupport saying it was fixed, so hopefully test it next couple of days.
  4. #634
    In EEP
    Hi about hu64 calculating bite was ok key cutting see good but cant open if i show on tent is smaller as original . i try change original drill this 2.5 mm have 2.65 maybe this is problem
  5. #635
    Oct 2017
    Quote Originally Posted by madaxe View Post
    "it does not connect. I click on find device button, software says Error: Failed to read device info" please install driver and reconnect the usb,then try again.
    About renualt emergency key,it's fixed on v4.0.2,some people have verified that it's ok.please check and if any problem please contact with me
  6. #636
    Mar 2009
    Quote Originally Posted by Xhorsesupport View Post
    I'll give it a go tomorrow, but I cant see why installing a driver on a PC will make a difference when I have already updated the XC-mini using that PC. Clearly the driver worked at that point. Is there a specific driver you'd like me to try ?
  7. #637
    Moderator
    PremierD's Avatar
    Jun 2009
    You are asking for advice mate ... take it .. and then question it if it doesn't work
  8. The Following User Says Thank You to PremierD For This Useful Post:
    z786 (4th January, 2018)
  9. #638
    Jul 2015
    Yes, it is OK with v4.0.2.
  10. #639
    Oct 2017
    The pc doesn't recognize the usb,driver and reconnection is a way to activate the recognization,if you there is problem still.please check your pm,I send to you my contact information,I'll check for you remotely.
  11. #640
    rob h's Avatar
    May 2011
    Get the shortest best quality USB cable you can find!
    Run as admin.
    Virus scan of!
    Test using the 2.0 and 3.0 USB ports.
  12. #641
    Mar 2009
    rob h: I only use good quality USB cables, that work with Tango, which is the most fussy USB device I have. Virus scan does not run by itself, only 1nce a month, of if I sense a problem. I am admin priv on all locksmithing PC's. Only got USB3 ports and powered USB3 Anker Hub in my setup, which has never failed even with Tango. None of which would explain why it worked well enough to update the XC-mini, which took 20 mins. Then stopped after the XC-mini software update :-)
    XHorsesupport: I got your PM and will contact you on Monday when I know your timezone. But looks to me like the PC is contacting the XC-mini, and starting the connection, because the XC-mini screen resets and changes colour. Do you have a specific driver you want me to try ?
    Also, is it possible to have a screen testing / alignment function put into the XC-mini ? Some of screen buttons are so small, and dont seem to line up very well, worse case for me is putting the bitting in manually for a HU64-2. The '1' button when I press it clicks the return to main menu button. Most other keys are fine because I can use Instacode Live, but cant see how to get Instacode Live to use HU64-2. A stylus would be good if you can say what sort will work, but I think the alignment function needs to be there too.
    Also, noticed a problem trying to cut TOY43 emergency blade for Prius (pic attached). The plastic part wont fit in the clamp to line the tip up. And if I clamp the metal part, the machine wont cut it becuse the tip doenst align.
    Also, shoulder aligned keys arent very accurately cut, because the shoulder is aligned by eye. It would be better if the shoulder were 'discovered' using something like the universal copy function (lots of small movements to find the change in width of blade). I had a (Silca) GT15R the other day where the shoulder was aligned correctly, or so I thought, but the cutter took the tip of the key off when it moved around to cut side 2.
    Still very happy with the machine, but getting rid of the small bugs will make it an even better machine.
  13. The Following User Says Thank You to madaxe For This Useful Post:
    fytfh (8th January, 2018)
  14. #642
    Jul 2015
    It always cuts the tip of the Fiat GT15R key even it is correctly aligned - BUG. There is a small "L" shape metal in the package what you can use to align the key to the shoulder.
  15. #643
    Jan 2017
    USA ����
    use the shoulder stop........................
    that thing on the right is the shoulder stop.........................
  16. #644
    Mar 2009
    I was cutting a key today and was looking at that groove on the clamp, thinking, hmm, its quite a wide groove, I bet a piece of metal will slide in there, and you guys had already thought of it. I'll try it out, thanks.
  17. #645
    Jan 2017
    USA ����
    https://youtu.be/uaGnwx4yYm4?t=57s
    that little guy right there
  18. The Following User Says Thank You to sleepyrz For This Useful Post:
    WRX 14 (10th January, 2018)
