Page 45 of 127 FirstFirst ... 3540414243444546474849505595 ... LastLast
Results 661 to 675 of 1900
  1. #661
    Mar 2009
    I found a bug today. I tried to cut code Z4213 onto HU100 for Vauxhall. I put code into Instacode Live, and sent it to XC-mini (Km03 on v 4.0.3). It cuts incorrectly. If I use XC-mini internal database, it cuts correctly. Please see attached picture.
    I would have sent it via PM but couldnt see how to attach the pic.
  2. #662
    Moderator
    PremierD's Avatar
    Jun 2009
    Looks like a mirror image .....
  3. #663
    Oct 2017
    Quote Originally Posted by madaxe View Post
    thank you for your feedback,I have given the feedback to engineer to check the software!
  4. #664
    Apr 2016
    Having problems with hu83 blades
    But only in the ignition?
    The genuine key works door and ignition
    The keydiy hu83 blade works the doors with a slight notch but the ignition doesn’t work at all?
    Tried both a 7 cut and a 7 cut ext
    )so the extra cut)
    Tried cut by code
    Tried correct and cut!
    Still no luck?
  5. #665
    Jul 2015
    Quote Originally Posted by clintezra View Post
    )so the extra cut)
    Tried cut by code
    Still no luck?
    I never had problem with HU83. Currently I use v4.0.2.
  6. #666
    rob h's Avatar
    May 2011
    First, check your cutter diameter in the settings.
    When you turn the doorlock, you say, there is a notch.
    So there is no more resistance, after the first degrees of turning.
    Or does it turn heavy all around?
    I think that your cuts are to deep,
    )so the extra cut)
    Tried cut by code
    Still no luck?
  7. #667
    Jan 2018
    CA, USA
    I have owned the Xc mini for about a month, love it, I’m new to making keys and mostly just do it as a hobby as I’m a Bmw enthusiast and just one more thing to learn about the vehicles.
    One questions might be right in my face but when i enter database key code HA00004416 example I’m given 2 choices (see image), how do I know from the code which I choose? I’ve gotten lucky all this time choosing the first one but recently comparing key cut to original last vehicle was the 2nd choice. Thanks for any help,
  8. #668
    wissamshaat's Avatar
    Oct 2017
    france
    Quote Originally Posted by cniksor View Post
    you can use instacode and connect it to condor to help
  9. #669
    rob h's Avatar
    May 2011
    Instacode gives me 2 options, and then comes up with 2 identical key cuts.
    Can you post the code, where you choose option 2. It should be in the machines history.
  10. #670
    Oct 2016
    Scotland
    Quote Originally Posted by rob h View Post
    Instacode gives me 2 different cuts for code HA00004416 (Screenshots attached)
    ISN 7506: 21233221
    ISN 7507: 23322121
  11. The Following User Says Thank You to WRX 14 For This Useful Post:
    rob h (23rd January, 2018)
  12. #671
    Jan 2018
    CA, USA
    yeah those are the two options i got when i cut that vehicles key, luckily i was making a spare key so when it didnt work, i compared the working key and that's when i noticed it was different, for a moment i thought i either 1. entered the code wrong, or 2. someone has previously changed ignition. i went back to XC mini to double check the code and sure enough, it displayed two options, i chose the 2nd and that matched the correct key cut. now i match the key to the cut before cutting key, but in a all key lost situation, im afraid ill be in a gamble to choose one. unless theirs a way to choose the correct one?
  13. #672
    Oct 2016
    Scotland
    In instacode we have just put the mech key code and selected BMW. If refine the search using vehicle year and model it may only show the one key cut.
    What year and model is it and i'll check?
  14. The Following User Says Thank You to WRX 14 For This Useful Post:
    cniksor (23rd January, 2018)
  15. #673
    Jan 2018
    CA, USA
    Quote Originally Posted by WRX 14 View Post
    your right, i entered the year make on instacode and it showed the correct one! thank you, problem solved! (it was a 05' 525i)
  16. #674
    Jan 2017
    USA ����
    Carry mechanical keys to cut so you don't mess up a more expensive key
  17. #675
    Mar 2009
    Exactly, the keydiy blades are very cheap, add a pair of mole grips and you can easily test the cutting.
