Page 48 of 127 FirstFirst ... 3843444546474849505152535898 ... LastLast
Results 706 to 720 of 1900
  1. #706
    melbourne, australia
    Quote Originally Posted by rob h View Post
    Better start using the silca platform. HYN17
    hyn17 isnt on my old condor, is it on the mini?
    Ill probably have to upgrade soon, and am tossing up if I should get a mini or look at a miracle or bianchi, any suggestions?
  2. #707
    rob h's Avatar
    May 2011
    HY21R HY18R.jpgHY21U choose HY18R
    Stick to the master, it can do these just fine!
    Quote Originally Posted by cqae View Post
  3. The Following User Says Thank You to rob h For This Useful Post:
    cqae (13th February, 2018)
  4. #708
    thanks Rob, ur a legend! Ill try that
    Aweosme mate, just cut it & all good, I was sure I searched all of them, but obviously I didnt, thanks so much!
  5. #709
    May 2013
    Quote Originally Posted by wissamshaat View Post
    Attachment 505036Attachment 505037
    thats what i have picture
    tryed lot of times and didnt worked
    These are VA2 profile. Cut it with VA2 and not VA6.
    I did one just the other day and worked perfect.....
  6. The Following User Says Thank You to obeids For This Useful Post:
    PierreTheron (7th March, 2018)
  7. #710
    wissamshaat's Avatar
    Oct 2017
    france
    Quote Originally Posted by obeids View Post
    there is no va6 profile in machine
    tried the va2 profile both numbers and letters and it dont works
    peugeot va2 blades work good
  8. #711
    kronk92's Avatar
    Sep 2016
    France, paris
    I tried to cut FO21 but it doesn't cut it well, there is some spacing , this photo is cut with 412443
  9. #712
    Greece
    you dont have put key ok on clump
  10. The Following User Says Thank You to kleidaras For This Useful Post:
    kronk92 (22nd February, 2018)
  11. #713
    kronk92's Avatar
    Sep 2016
    France, paris
    This is the maximum that i can do
  12. #714
    Jan 2018
    CA, USA
    not sure if the instacode got updated but again if i enter a key code im getting two different options, even when i put in year and make and model i still get two key cuts
    ha00005942 2006 bmw 530
    i took a guess and got it right but i cant keep guessing.
    am i going to a wrong setting?
  13. #715
    Jan 2017
    USA ����
    Quote Originally Posted by kronk92 View Post
    adjust the screw in the back
    and tap back of key with plastic hammer like bump hammer to make sure it is fully seated against stop
  14. The Following User Says Thank You to sleepyrz For This Useful Post:
  15. #716
    kronk92's Avatar
    Sep 2016
    France, paris
    thank you guys, i did hammer the key to fully enter and now it cuts well !
  16. The Following User Says Thank You to kronk92 For This Useful Post:
    yugo45 (7th March, 2018)
  17. #717
    rob h's Avatar
    May 2011
    Quote Originally Posted by cniksor View Post
    Consider using a lishi decoder.
    The direct reader might be enough to select the correct one.
  18. #718
    Jan 2017
    USA ����
    no they have added many new cards to the system
    they even have cards for the new m4 clamp that has not even come out yet
    check gm26r if you want to see the m4 clamp setup
    they are adding many new things and making it more capable
    but it is making it hard for the people that dont know the intricate little details on how to determine what card to use
    i am slowly learning how to figure it out case by case
  19. #719
    Jan 2017
    USA ����
    hu100 10 cut is wrong still..........
    cuts too far to the left
    good thing i made a custom key file for it
    how is it im able to get it right on the first try having never used their software before and they still cant get it right and they wrote the damn thing....................
  20. #720
    Jan 2013
    Hi i have to cut key by pictures but doing some wrong i decode key by eyes 13231222 but not work on the car
