Page 49 of 127 FirstFirst ... 3944454647484950515253545999 ... LastLast
Results 721 to 735 of 1900
  1. #721
    rob h's Avatar
    May 2011
    Code looks fine.
    Post pictures of new Key.
    Both sides!
  2. The Following User Says Thank You to rob h For This Useful Post:
    fytfh (6th March, 2018)
  3. #722
    Jan 2013
    Quote Originally Posted by rob h View Post
    Code looks fine.
    Both sides!
    This is new key
  4. #723
    Jan 2013
    Code looks fine.
    Both sides!
    maybe i decode wrong must be 24342333 how you think?
  5. #724
    rob h's Avatar
    May 2011
    Cutting looks fine.
    Why dont you use caliper, to measure the old key?
    Both cuts are known by instacode.
    The 24342333 was my second guess to.instacode: 04014
  6. #725
    Jun 2014
    Anyone done a HU134 for a Kia Venga with Condor.
  7. #726
    PierreTheron's Avatar
    Centurion,South Africa
    No only megane2 and working 100% although i broke a few tracers
  8. #727
    Dec 2010
    Default mitsubishi 1999
    Always the same story, tell the tip
    This has a solution?
  9. #728
    rob h's Avatar
    May 2011
    Quote Originally Posted by jaelgti View Post
    Mit8 or what?
    Mini or oo7 condor?
    Sw version?
    1221113243
  10. #729
    Jan 2017
    USA ����
    mazda?????????
  11. The Following User Says Thank You to sleepyrz For This Useful Post:
    jaelgti (13th March, 2018)
  12. #730
    Dec 2010
    Sorry,mitsubishi and Cóndor mini v. 4.0.4
    Thank you
  13. #731
    rob h's Avatar
    May 2011
    Thank you
    Could it decode the key proper?
    Could you decode it, any other way?
    It looks a bit different, the cuts nearest to the tip.
    Also your new blade, it is the same lenght?
    It appears longer. And it is missing grooves.
    Measured both from shoulder to tip.
    Your cuts shoulder be something like this:1221113243.
    Not 1221113242
  14. The Following User Says Thank You to rob h For This Useful Post:
  15. #732
    Jan 2017
    USA ����
    It looks like you are trying to cut a Mitsubishi key onto a Mazda keyblank..............
    Either way that's the wrong key its way longer from the shoulder to tip
    Not machine error
    User error
    What car is it????????
    What keys are those??????
    Help us help you and give us more information
  16. The Following User Says Thank You to sleepyrz For This Useful Post:
  17. #733
    What is difference
    Key cutting and Correcting&Key cutting option
  18. #734
    Jan 2017
    USA ����
    you get these options when you decode a key with the tracer
    if you choose cut key it will make exact duplicate of key that it traced even if the key is worn down
    if you choose correct and cut it will fix key back to original specs
    like if the key is worn down a little it will bring it back up to factory specifications
  19. The Following User Says Thank You to sleepyrz For This Useful Post:
    kronk92 (19th March, 2018)
  20. #735
    Jun 2016
    Condor XC-009, anyone get the news?
  21. The Following User Says Thank You to crazylou2017 For This Useful Post:
    Weasel3 (27th March, 2018)
